Anyone else not abl...
Anyone else not able to notice any difference in tyres ?
[#13021647]
Or is it just me ?
I read some of the threads and then think back to myself about what tyres i have fitted and realise sometimes i'm not even sure what i'm running.
Currently i think the Trek is on Bontrager SE5, which i don't know, but have the exact same tread as a Minion... but what compound, grip etc that equates to, i have no idea.
I've run everything from a Magic Mary, to an Assegai on the front of my last few bikes, i've even thrown on a Hans Dampf but for the life of me, they just feel the same to me.. i don't think any have more/less grip, bite, feel... but i dunno... Maybe i can't tell the difference.
Posted : 30/10/2023 8:21 am
funkmasterp, leffeboy, funkmasterp and 1 people reacted
I think it will depend on your riding style and location. If you ride steep / soft / wet / rooty you will notice.
also different tyres will allow different pressures and have better / worse rolling resistance.
There is, in fairness, not a huge difference between good tyres. I tend to stick with the same tyre style I have used for years as familiarity is always good
Posted : 30/10/2023 8:32 am
I can tell difference between carcass size ( comfort) and rolling resistance but rarely is grip any more noticeable to me between brands/ compounds.
I guess  it depends a lot on where you ride though, I tend to avoid mud and grass in poor conditions and look to ride on well drained surfaces when it's wet.
Posted : 30/10/2023 8:35 am
Yes, massively
Old specialized tyres (butcher/purgatory) tried to kill you, wet or dry
Ultra soft magic Mary's give incredible grip. Switching to a normal soft on the back the front end will stay in check, but the back will occasionally break away, but printable and controllable.
Currently on soft Eddy Currents front and back and they are giving me a decent level of grip.
I do ride on the ragged edge of my skills a lot of the time though
zerocool and zerocool reacted
 Spin
Apart from one or two total howlers over the years I don't notice much difference.
I'd be able to tell the difference between categories of tyre i.e. I'd notice a hard conditions tyre not working in the mud but it's unlikely that I'd notice the difference between two mud tyres in the mud.
I do wonder if the amount some riders agonise over it is a bit the emperors new clothes.
Posted : 30/10/2023 8:36 am
norbert17, daviek, scotroutes and 3 people reacted
I'm like this (and I bet a lot more are secretly) about lots of bike parts.
3k bike or 6k bike,I wouldn't notice the difference. Apart from maybe weight when putting it in the car...
I've used Nobby Nics for what feels like forever... New bike I have Maxxis (assegai front and something else on the rear). Now, i'm sure they are excellent tyres, and I got the expensive versions, but the grip is perceptively different to the Nobby Nics....
I'm not saying they are worse, just different, but I was so used to where the Nic's lost grip, or where the transition was from centre tread to side tread.... I'm not 100% sure the Maxxis will stay on....
Posted : 30/10/2023 8:41 am
Swap out your SE5 for a pair of XR1's and I think you'll notice a difference!
Posted : 30/10/2023 8:59 am
thols2, Simon, thols2 and 1 people reacted
I can notice differences between tyres, but like Klunky says, it depends where you're riding. Whizzing round a trail centre I might notice rolling resistance on the back, but that's about it. Bouncing in straight lines down dark peak gritstone trails, I don't notice a lot. Sketchy steep muddy woods and you can feel loads of difference in braking, cornering, lateral grip that you wouldn't spot elsewhere.
That said, I don't know if I would notice any difference between a DHF and a DHF rip-off from another brand, where there are definite differences between a DHF and a DHR.
Half the change is probably comparing worn tyres to new ones, mind.
Posted : 30/10/2023 9:01 am
kelvin and kelvin reacted
I think I’m a surfaced trail centre most tyres will work - especially if it’s dry.
When things get murky and wet and steep and covered in roots / loose ground then different tyres make a huge difference to me.
For example there’s a greasy steep ish decent in the local woods - the ground there is red and a little bit clay like. Around now if you tried to descend that on anything other than a Hillbilly / 2.6” Magic Mary type tyre there are a couple of spots where you’re going to struggle to make your turn. I had this last year - went the 1st week when I had a wild enduro on and it clogged / went straight on at one point. Next week in similar conditions I’d changed for a hillbilly and it braked better on the way down the steep bit and just turned perfectly where the WE went straight on.
Posted : 30/10/2023 9:06 am
Tyres are maybe the only thing I do notice.
Suspension goes up and down and to me it's all the same but good  tyres makes all the difference. There are some tyres I just don't get on with.
Good Road tyres I can't really tell the difference
Posted : 30/10/2023 9:10 am
 Spin
Apart from one or two total howlers over the years I don’t notice much difference.
I’d be able to tell the difference between categories of tyre i.e. I’d notice a hard conditions tyre not working in the mud but it’s unlikely that I’d notice the difference between two mud tyres in the mud.
Actually, having thought about it, I do notice some differences between tyres but unless it's something disastrous, I'd usually adapt my riding to it rather than change the tyre.
Posted : 30/10/2023 9:14 am
Doubt I could tell similar rear tyres apart on a blind test.
Front tyre is a different story - think it's one of the most important components on the bike. Rare MTB example of something where small differences matter and can be felt riding.
towpathman, dc1988, towpathman and 1 people reacted
My first two decent bikes were specialized which came with purgatory tyres fitted.  For years I thought they were decent tyres and were much cheaper to replace than other brands.  Then one day I decided to try minions and holy Jesus they were so much better it made me realise that the purgatory just weren't as good on the trails I was riding.  So much more corner and braking grip.
Posted : 30/10/2023 9:20 am
I think compound makes a difference, but at the same time, I think the major manufacturers have got that pretty much nailed. I'd happily run a front tyre from Schwalbe or Maxxis I think they both make excellent tyres. I think it comes down to what you feel confident riding, I've been more or less exclusively on Maxxis for years now, so I know how they'll perform, and for instance I "know" that I don't have much confidence in a DHF on the steep stuff in Calderdale, but I'll be fine on a DHR, or Assegi. I've put that in scare quotes becasue that's based primarily on a couple of rides a few years ago when a partly worn out DHF, I'm pretty sure if I stuck a new one on tomorrow, It'd be fine.
Find the tyre that performs well for you, and it's a revelation.
Posted : 30/10/2023 9:26 am
Probably depends on the type of tyres your using - there's minimal difference between a maxxis minion and a conti kriptotal on the front, but as soon as I put a conti Argotal on, there's a huge noticeable difference (all 2.6)
I put my big boy pants on and raced with a Forecaster Mk1 in the wet yesterday.  despite the lack off/low knob height it was amazing - all to do with the compound.
I've avoided Maxxis as I'm not a "leaner" and had some scary moments with the transition with a High Roller many years ago,  However my Occam came with a DHF/Dissector maxterra combo and I find them remarkable.
Posted : 30/10/2023 9:36 am
Front tyre is a different story – think it’s one of the most important components on the bike. Rare MTB example of something where small differences matter and can be felt riding.
I agree with this.
It's one of the few bits of MTB kit that I'm pretty sensitive to and clued-up on the difference it makes.
By contrast, I can tell when something is off with my suspension but it's rare that I can accurately feel what the problem is. Getting better at that, but still trial-and-error a lot of the time.
I tend to notice they differ in price a fair bit.
As above, conditions dictate. Summer any old tyre works, Winter or wet weather I'll swap to something specific to where I'm riding. Or go to the pub instead.
Posted : 30/10/2023 9:44 am
same bike i run se5/se4 and xr3/xr2 there's definitely a time and a place for each
My full sus i tried a HR2/SS combo for the summer which was mostly good, until i went into steep loamy stuff and had the worst time, i historically run a dhf/dhr and swap the front for a shorty for the worst of winter
i cant really tell the difference between my aggressive sets of tyres. but between the aggressive, xc and "trail" set there is definitely differences. I can feel the drag/speed differences. and i can feel sketchy when taking the tyres out of their optimum conditions
Posted : 30/10/2023 9:45 am
(I think STW Benji just took a deep intake of breath....)
Yes I can. More on the 'that is not great in comparison' end of the spectrum though.
I fond that I can feel suppleness and their ability to absorb some of the trail chatter.
I can definitely feel ultimate grip levels - compare a small blocked XC tyre with a Magic Mary for example.
I can also feel that some tyres 'let go' in different ways. So my Goma's are brilliant up until they let go quite suddenly, whereas I found my older XR4's and Mountain Kings (black chilli) 'smear' when then go.
I found my cheap OEM Nobby Nics to be fast but completely awful in any damp, and yet when I put on aftermarket Nobby Nic's they seem to be more predictable and hold on better when braking particularly.
Posted : 30/10/2023 9:46 am
Nope, I can definitely tell the difference especially when the going gets steeper/rougher.
In fact I can tell the difference when I've too little/much pressure in the tyres - but TBH same with cars & motorbikes (racing them too), always have had the 'feel'.
OP, if you change the tyre pressures can you 'feel' they're different?
Also, maybe if you'd just own & ride the same bike for longer than a month you'd start to get a 'feel' for changes...
Posted : 30/10/2023 9:54 am
OP, if you change the tyre pressures can you ‘feel’ they’re different?
Not really.
Also, maybe if you’d just own & ride the same bike for longer than a month you’d start to get a ‘feel’ for changes…
Ho ho... so amusing.
Posted : 30/10/2023 10:04 am
Yes I can feel the difference just after I've changed tyres.
I can also feel the difference between pressures.
Pink Bike did a series of interviews on this last year, and it was interesting that most of the industry insiders seemed to feel that compound was more important than tread pattern.
Having said all that, I learn to ride around the limitations of the tyres. Also everything is a compromise. Excellent grip invariably means more rolling resistance.
I used to be on Maxxis, as they're excellent, however I'm in the process of transferring to Specialized as I think the cost benefit ratio is better.
Posted : 30/10/2023 10:05 am
Not really.
blimey - I can really tell the difference in tyre pressures.
weeksy - you used to do a lot of motorbike trackdays, didnt you?
Could you feel the difference in different tyres, or even pressures on your motorbike? I used to do car trackdays in a caterham 7, and the difference between different tyres was significant.
Posted : 30/10/2023 10:10 am
I once took my motorbike for a spin down the B184 after not having used it for a while. Felt the back wheel squirm in every corner and came back thinking the roads were really greasy.
Turns out the back tyre was at 4 psi....
Posted : 30/10/2023 10:14 am
OP, if you change the tyre pressures can you ‘feel’ they’re different?<br />Not really.
I'm a bit confuzzled (doesn't take much). You seem to spend a lot of time fettling with different shocks because you can feel the subtle differences, yet you can't tell any differences in changing tyre pressures?
Apologies if it appears I'm picking on stuff you say, I'm not per se - but you do put a lot of info on here and some of it seems conflicting.
A few (2-3) psi makes a hell of a difference to how my bikes feel
Posted : 30/10/2023 10:18 am
blimey – I can really tell the difference in tyre pressures.
weeksy – you used to do a lot of motorbike trackdays, didnt you?
Until recently i ran 20F 22R the same as my lad.. Recently i've gone to 24F 26r but i can't say i've even noticed no. I was reading a bit about what pressures the Enduro racers were running and they were all higher than my 20/22, so thought i'd experiment with higher pressures. Most of that was on the Slayer on completely different rubber to the current SE5's, but i set them to 24/26 when i got the bike and that's what i've ran since.
I've done 150+ trackdays and 4 years of racing motorbikes. I wasn't great in terms of feel on those i'll admit, some people went faster on new Supercorsas/Racetecs, i fitted a few for races but still went the same on them as i did on old tyres. In terms of pressures, i rarely changed pressures, i just ran whatever we were told by the tyre techs, so i didn't experiment much. But since the racing days i've done plenty of trackdays (until i stopped riding bikes about 12 months ago) and even using different tyres, from touring tyres to full race compound, i can't say i noticed a massive difference. My 'pace' is my pace, irrespective of what i've got on there really, that's how fast i went, just me speed.
Posted : 30/10/2023 10:20 am
Just swapped over from spesh hillbilly 2.6 and eliminator 2.6 old gripton both with rimpact inserts over to new hillbilly 2.4 t9 and butcher 2.3 t9 both trail carcass without inserts. The carcass is considerably more rigid, hoping the new compound/reduced width will work better in mud/loam and wet roots on Exmoor. Will report back if I can tell a difference.
Posted : 30/10/2023 10:21 am
Give me grip every time. I can feel the difference when I put something a bit faster on the back in the summer, but on the front, I'm happy to push a good compound Assegai around the place just for the confidence of not having to worry about it regardless of how much extra weight it might be (and in reality, we all worry about weight too much anyway)
I can feel the tyre pressure difference, but I pump tyres every ride so never really ride with anything other than my settings.
Posted : 30/10/2023 10:22 am
As someone who is utterly rubbish off road, even I can tell the difference in tyres. Something nice and grippy makes a huge difference and helps to compensate for lack of talent, even at the pedestrian speeds I ride at
Posted : 30/10/2023 10:27 am
Weeksy, I’m sure you’re subconsciously feeling the difference in tyres, you just haven’t NOTICED it. I swear tyres (tread pattern, compound, casing and pressure) matter way more than anything else in mountain biking and anyone riding near the limit will notice a difference in a blind test if they actually focus on it.
Posted : 30/10/2023 10:36 am
My ‘pace’ is my pace, irrespective of what i’ve got on there really
There's your answer. I can't really tell the difference these days because I don't ride as much and when I do it is generally a medium paced pootle round Swinley. I don't think I push the bike or myself enough to notice any change other than fitness levels. In contrast, when I used to ride everything as fast as I could I was very sensitive to tyres. It would take me weeks or months to build confidence in a new tyre.
All my tyres are similar width and look very much like a minion (even though not made by maxxis)
So in that respect theres not much difference
I definitely notice less supportive sidewalls, especially on rear of hardtail!
But high grip compounds make a huge difference
Im sure theres loads of rubbish talked about tread patterns, damping, etc  but Sticky rubber is king
you can learn to ride any tread pattern ime, but theres no substitute for sticky compounds
2.6 butchers on front of both bikes one is T7, other T9t
he grippier T9 is a great when riding in the edge (of my ability)
Posted : 30/10/2023 10:39 am
Pretty much every ride we do atm will have some off camber roots somewhere. And maybe some limestone.
Tyres definitely make a big difference on them
Posted : 30/10/2023 10:40 am
Tyres are the black knobbly and a bit squidgy tubes that go on the edge of the wheels, right?
Posted : 30/10/2023 10:43 am
On the same bike, Minions vs 'old' Nobby Nics - the Minions have far better grip and more predictable, but are much more draggy. The Nobby's are good for XC and distance as they roll well, but I find they let go on off camber when it's muddy - the old ones have the knobbles in a 'line' across the width of the tyre,  so once they slide sideways they are going.
Posted : 30/10/2023 10:44 am
“My ‘pace’ is my pace, irrespective of what i’ve got on there really”
I guess if you never run out of grip then you might never feel a difference. I ride natural trails 99% of the time and the available grip varies a lot, so even if I try to ride at the same speed all year round I’ll run out of grip when it’s dry and loose or wet and muddy (you can only ride our local trails at full speed for a very small proportion of the year).
integra and integra reacted
Interesting thread. I can't tell much difference. I remember everyone talked about HR's killing people. Can't say I ever noticed. I didn't die. The only time I felt a difference was my previous Giant Reign came with standard Hans Dampfs on it. They were brutal, zero grip on rock. They actually felt dangerous to me. Got rid. I can tell a little bit of difference in big enough pressure changes.
I am not sure I can. I tell myself I can but I think I am just blaming the tyres for my lack of skill. Having a slow day…..it’s the tyres they are too draggy. Front end washes out it’s the tyres…..not the pressure/ground condition or lack of skill. Same for the rear. Have a great day…..it’s the tyres they are great. Etc etc. If I change tyres and the new ones feel so much better than those they replaced it’s probably because the old ones were getting worn so obviously the new ones are better.
I reckon most average riders won’t see much difference in decent tyres as long as they are not running an xr1 in slop or a muddy Mary in a trail centre.
the next ‘what tyre’ thread can be answered with ‘whatever you want because most of us cannot tell the difference’.
Posted : 30/10/2023 10:46 am
My ‘pace’ is my pace, irrespective of what i’ve got on there really, that’s how fast i went, just me speed.
The answer is I think that you've never really pushed it, otherwise you'd know...
but for the life of me, they just feel the same to me.. i don’t think any have more/less grip, bite, feel… but i dunno… Maybe i can’t tell the difference.
Ride harder.
Posted : 30/10/2023 10:48 am
thols2, singlespeedstu, thols2 and 1 people reacted
Ride harder.
Why didn't i think of that... i'll just got 50% faster next time...
Jeez.
Posted : 30/10/2023 10:49 am
The answer is I think that you’ve never really pushed it, otherwise you’d know…
Yeah that'll be it..
Posted : 30/10/2023 10:54 am
@stcolin
I had an HR2 on the front of my hardtail a few years back, was happy with it
as posted above I chucked it on my full sus for the summer, I was also happy for most of my riding, until I went somewhere steep, damp, rooty and loamy and I totally noticed the difference between that an a DHF, that tyre I shall call a trail tyre going forwards, damp roots was the decider that it should never go back on the front of a bike where i might ride in all sorts of conditions
Posted : 30/10/2023 10:56 am
Page 1 / 3
