as above.thinking of converting my 36 talas to a float and spacing it to 150mm.is it straightforward and what are the costs involved.ta
Posted : 14/04/2010 10:26 pm
ive got the bits on the way to do that with my 32 forks. Bits around 60 quid and its easy. On the 32 anyway presume the bigger forks are similar. Swap inner leg spacer swap out left leg internals. Do the fluids and tighten and pump up ๐ thats about it. If you call mojo they will sell you all the bits in a pack saves ordering bits as they know all the bits you need. Hope that helps mate
Posted : 14/04/2010 10:31 pm
