any tips for bleedi...
[Closed] any tips for bleeding slx brakes?
2 Users
just sbout to take the plunge and do it myself for the first time - anyone got any good tips??
ta
Ben
Posted : 18/05/2009 2:04 pm
If you're bleeding without a syringe, don't let the reservoir go empty.
It is easier to pump fluid through the caliper using a syringe so I am told but I've never had a major prob by doing it the shimano way by adding fluid and pumping.
Take your time.
Make a note how far and how the levers feel/move now before you bleed.
If done inside, use newspaper on the floor before other half comes in and tells you off for spilling mineral oil in the lounge :O)
Posted : 18/05/2009 2:09 pm
cheers zaskar - im actually doing it in the kitchen so that is a good tip!
just found a big old beach towel that should do the job nicely!
Posted : 18/05/2009 2:11 pm
