Any Google SketchUp...
[Closed] Any Google SketchUp users on here?
I've downloaded the first version and I'me trying to "cut" holes out of a shape. Using push/pull just seems to remove only a partial section. Is there a tool where you can highlight on a shape within a shape and cut the whole thing out?
Posted : 08/09/2015 12:29 pm
been ages since I used it but I think you push pull all the way through then click and deletye the final slither?
Aternatively can you create the inner part as a solid then subtract it?
Thats what I do in AutoCAD
Posted : 08/09/2015 12:46 pm
you can use the intersect faces on the edit pull down
Posted : 08/09/2015 1:48 pm
Is the first shape 2D or 3D? If 3D, you may need to make it a group or component before you can use the intersect tool.
Posted : 08/09/2015 1:51 pm
 Leku
highlight section and 'delete'?
Posted : 08/09/2015 1:55 pm
Yep, one click on the section and "delete".
Posted : 08/09/2015 3:02 pm
Thanks all. I push it back to a 3D object which kept the areas I wanted to erase 3D. Then I erased all the lines and fill of the raised areas. Sorted!
Posted : 08/09/2015 3:21 pm
I've now got the 2D object shaped the way I want it, but can't pull it into a 3D object. I'm thinking there's a small point somewhere that I need to erase maybe? Weird, as push/pull has worked on everything else...
Posted : 08/09/2015 4:35 pm
