Angle reducer heads...
[Closed] Angle reducer headset Cube Stereo
Hello,
Got a 2013 Cube Stereo 140 SHPC 29er and want to slacken it by a degree with an angle headset. Is it possible with this frame (carbon). If it is possible, has anyone fitted one and if so - which one works the best? Been looking at Works Components and Cane Creek but not sure what actual size/spec headset I need!
Thanks
Posted : 06/09/2016 3:05 pm
Looking at my 160 hpc i think the little bearings sat in the frame will prevent you using an angleset. I think the way forward may be offset shock bushes.
Posted : 06/09/2016 5:54 pm
Double post sorry
I don't think it works, as breninbeener says it uses an internal headset so no cups to replace- or so I believe, I nearly bought one of these but was put off by that.
Posted : 06/09/2016 6:00 pm
