Am I being a muppet...
[Closed] Am I being a muppet?
[#2801582]
Don't answer that...answer this.
I bought Mrs Geordie a nice set of Superstar CNC Nano Thru Pin pedals ([url= http://superstar.tibolts.co.uk/popup_image.php?pID=194&osCsid=d6a3af7bfbb0d45ce47a1c194c851652 ]here[/url]) which I attempted to fit today. However, there appears to be no flat sides to the 'spindle' which will allow me to use a spanner to tighten the pedal to the crank arm.
Am I missing something obvious (probably), or do I need a specific tool? The 'spindle' has a slightly oval cross-section, with no flat edges at all.
Cheers,
Andy
Posted : 29/05/2011 9:51 pm
allen key socket on the end of the axle?
Posted : 29/05/2011 9:53 pm
Allen key from behind?
Is there an alan key 'hole' that you can get to through the back side of the crank arms?
Use an allen key from the back of the crank.
Posted : 29/05/2011 9:54 pm
If you look on the end of the pedal axle, there is a fitting for a allen key.
Posted : 29/05/2011 9:57 pm
5 people can't be wrong - thanks folks, will take a gander tomorrow.
(Skulks back in to the shadows suitably embarressed).
Posted : 29/05/2011 9:58 pm
has anyone mentioned the possibility of an allen key fitting yet ?
Posted : 29/05/2011 9:59 pm
Trailmonkey not sure they did, it's a good idea though
Posted : 29/05/2011 10:02 pm
So, I think the answer to your original question is... Yes you are 😆
Posted : 29/05/2011 10:05 pm
Posted : 29/05/2011 10:06 pm
my xtr pedals use an allen key. Try that
Arc weld if there are no allen key holes
Posted : 29/05/2011 10:08 pm
8mm Allen key
Posted : 29/05/2011 10:10 pm
I bought the same padels a few months back and also found them lacking any way to engage a pedal spanner. In the end I had no choice but to use the 8mm allen key hole.
Posted : 29/05/2011 10:28 pm
Molegrips round the axle should work...
Posted : 29/05/2011 10:37 pm
get an angle grinder and make a couple of flats on them, if you are a weight weenie go mental with the grinder.
Posted : 29/05/2011 10:42 pm
Large rock should do it.
Posted : 29/05/2011 10:43 pm
Nuke it from orbit. It's the only way to be sure.
Posted : 29/05/2011 10:44 pm
get some steel bar and file it into a hexagonal shape measuring 8mm across the flats. There is then a secret part on the end of the threaded bit you can use this home made tool with 😉
Posted : 29/05/2011 10:50 pm
Own it with bombers. With a baby robin, on a conveyor...
Alternatively, an 8mm allen key should see you right.
Posted : 29/05/2011 10:59 pm
A real man would have hammered it in by now
Posted : 29/05/2011 11:04 pm
A real man would have [s]hammered in [/s]fitted it with his fingers by now
FTFY
Posted : 29/05/2011 11:07 pm
Hold the pedal axle in your hand and spin the rest of the bike in the air. Don't forget one side is a left hand thread.
Posted : 29/05/2011 11:10 pm
[b][i][u]ALLEN KEYS[/u][/i][/b]
Posted : 29/05/2011 11:35 pm
[img] [/img] [img] [/img]
Posted : 29/05/2011 11:43 pm
Posted : 29/05/2011 11:48 pm
Posted : 30/05/2011 7:43 am
Sir Sugar is gay?
Posted : 30/05/2011 7:49 am
NOT
Posted : 30/05/2011 8:06 am
start a thread slating superstar products and saying how poor the customer service is. These people need to be stopped.
Posted : 30/05/2011 8:26 am
bruneep - Member
Sir Sugar is gay?
I think you missed the point, [b]Alan[/b] Sugar - [b]Key[/b] West Florida.
Posted : 30/05/2011 8:47 am
on the outside edge of the pedal (edge opposite the crank arm) you should find a cap that can be removed.
remove this and proceed to disassemble pedal until you are left with it completely in bits.
Take the axle and about half way along file two falts parellel to each other.
Using a 12" adjustable spanner or large mole grips tighten the axle into the crank and re assemble pedal in situ as it were.
Once assembled you won't be able to see the flats and they'll look bob on kid.
Posted : 30/05/2011 11:00 am
Mental Mickey - Member
bruneep - Member
Sir Sugar is gay?
I think you missed the point, Alan Sugar - Key West Florida.
Posted : 30/05/2011 1:54 pm
Posted : 30/05/2011 2:04 pm
bruneep - Member
With all due respect, it's yourself you need to be rolling eyes at for asking such stupid questions. 😉
Posted : 30/05/2011 2:10 pm
Can't believe no one has told you that the flats have been missed off. It's poor quality control. Send them back and demand a refund!
Or, get an old pedal spanner and file a corresponding round profile into it that will match the new pedals.
Posted : 30/05/2011 2:16 pm
Immerse them for a few weeks in a solution of salt water and mud until the bearings are suitably seized. Hey presto, the spindle will now rotate when you turn the pedal, allowing easy tool free installation.
Posted : 30/05/2011 2:39 pm
with all due respect, it's yourself you need to be rolling eyes at for asking such stupid questions.
[url= http://www.urbandictionary.com/define.php?term=whoosh ]WHOOSH[/url]
🙄 again
Posted : 30/05/2011 4:19 pm
Have you tried using magic?
Posted : 30/05/2011 7:53 pm
Leave it in the shed with a glass of sherry and the pedal pixies will have it sorted by morning.
Posted : 30/05/2011 11:20 pm
I hate to disagree with most of the posts above but while I have found that an 8mm allen key works very well on both my XTR and PDM959 pedals it is in fact a 6mm all key which is required for my GF's PDM540s. You should all be ashamed of yourselves for jumping to conclusions.
Failing that, you will need some celery, a magic cat and a tapir.
Posted : 31/05/2011 12:25 am
A square tapir?
Posted : 31/05/2011 12:38 am
file a small slot into the axle near the crank and use a sharp chisel and hammer to tighten. job done.HTH. or just use molegrips with a special ' extender ' tube fitted for leverage. 🙂 just to be sure.
I have just made all of this up. Just use allen keys.
Posted : 31/05/2011 12:46 am
