Am I alright to use...
[Closed] Am I alright to use Shimano centrelock rotors with Avid Juicy 3s?
I'm upgrading the missus' Commencal from V-brakes to Avid Juicy 3s but her hubs are Shimano centrelock, am I alright to use Shimano centrelock rotors? Will there be any compatibility issues?
Posted : 17/10/2011 6:52 pm
Yes. No
Posted : 17/10/2011 7:00 pm
Some of the high-end Shimano rotors with the big spider will foul on the pad tabs, however you'll be fine with the cheaper ones.
Posted : 18/10/2011 12:32 am
The cheaper ones can often only be used with resin pads though. You can also buy 6 bolt adaptors if you want to run 'normal' rotors.
Posted : 18/10/2011 12:35 am
why can the cheaper ones only be used with resin pads?
Posted : 18/10/2011 8:02 am
I'd bought a pair of the C/L rotors before noticing the 'resin pads only' marker.... I only paid £15 for the pair, so thought "what the hell" and stuck them on with my Juicy 3's..... 8-9 months later and a few sets of semi-organic pads, and they look no more worn than any other disc's I've used, and they seem to perform spot on too.
Posted : 18/10/2011 8:47 am
They seem pretty soft, and also rust if you leave them outside all the time, so I guess using sintered pads (not semi-organic) pads would wear them down.
Posted : 18/10/2011 4:13 pm
mine fouled the brake tabs so I cut 'em off and now they work fine.
Posted : 18/10/2011 4:20 pm
For what its worth I am running an XTR splined rear rotor with a Magura Louise caliper - no issues here.
Posted : 18/10/2011 4:21 pm
