alternative bar and...
[Closed] alternative bar and helmet mounts for magic shine/ deal extreme lights ?
these type
looking for something as an alternative to the o rings
Posted : 06/10/2011 4:29 pm
Expect lots of ppl to tell you your fussing over nothing:
http://singletrackworld.com/forum/topic/magicshine-et-all-bike-light-handlebar-mounts
I haven't followed this up admittedly, as I already have one mount I swapped from my P7 to me XML light.
Posted : 06/10/2011 4:32 pm
cheers zippy,
have been experiencing some slippage on my rigid bike with os bars ๐Ÿ™
Posted : 06/10/2011 4:37 pm
I agree ๐Ÿ™‚
A few wraps of self-amalgamating tape has mine holding rock steady in all conditions with the 'O' rings
Posted : 06/10/2011 4:40 pm
i did this mod.. works a treat and is cheep as chips
[url= http://singletrackworld.com/forum/topic/new-magicshine-with-waterproof-battery ][/url]]handle bar quick release mod[/url]
scroll down youll see it
Posted : 06/10/2011 4:54 pm
will give the tape ago for a quick fix,
cheers craig 1975
Posted : 06/10/2011 5:16 pm
I've got some stick on velcro you can have* that'll stop it moving.
*I'll swap it for two Nates. ๐Ÿ˜‰
Posted : 06/10/2011 5:20 pm
you have a deal stu ๐Ÿ˜€
Posted : 06/10/2011 5:27 pm
For a helmet mount I use the same technique I use for my Exposure Flash as the mount is similar - get a cork cut a flat on it lengthways don't take too much off, then put the cork flat side to the helmet and put the rubber band around the cork and through the helmet and back to the light.
Posted : 06/10/2011 8:11 pm
very inventive myheadsashed, and I happen to have quite a few corks ๐Ÿ˜€
Posted : 06/10/2011 9:06 pm
just done that cheers ๐Ÿ™‚
Posted : 06/10/2011 9:15 pm
 dobo
is the a uk source of o rings anywhere?
Posted : 06/10/2011 10:09 pm
I found that an old Cateye ABS mount will screw on in place of the O ring mount then just fitted the other mount to the bars. Works a treat. No good if you havn't got an old set of Cateye lights though obviously!
Posted : 06/10/2011 11:39 pm
dobo, cut a 1cm cross section of inner tube and fold it in half. Mine came with the O-rings missing, so this is what I used. Worked just fine.
Posted : 07/10/2011 6:40 pm
