Alfine - what bits ...
[Closed] Alfine - what bits do you need to get?
I'd like to fit an Alfine hub to my Soloist.
What bits do I need to get other than the obvious hub and shifter?
Thanks in advance for any help
Ken
Posted : 30/12/2009 12:13 pm
[url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=35105 ]One of these[/url]
[url= http://www.cyclesportsuk.co.uk/product_info.php?products_id=6660 ]And one of these[/url]
You might need to remove the guard and flip the cog to get the chainline right though.
Posted : 30/12/2009 12:16 pm
have a look at on-one for cheapy Alfine hubs although they're out of sprockets and fitting kits...
Posted : 30/12/2009 12:17 pm
My guard seems to be very good at clooging with shite, so might be worth discarding. Obviously you need one of these as well:
Posted : 30/12/2009 12:31 pm
CRC have them, for only £4 more, with all the other bits. You will need a specific shifter, too.
Posted : 30/12/2009 12:34 pm
But you mention shifter in the OP, so I'll just naff off now.
 mboy
Spokes, nipples and a rim might help too! 😉
When it comes to the cog, if you can, order a Shimano Nexus one rather than the Alfine one. It doesn't have the plastic guard fitted, which means it's less susceptible to clogging with mud!
Posted : 31/12/2009 3:14 am
Posted : 31/12/2009 9:26 am
If you are not running splined discs, you'll need a rear one or a splined to 6 bolt adaptor (a mate couldn't get the mavic adaptor to work).
Posted : 31/12/2009 9:33 am
http://www.singletrackworld.com/forum/topic/what-exactly-do-i-need-for-an-alfine-set-up
I asked the same q last winter.
Posted : 31/12/2009 9:51 am
