Alfine - Santa Cruz...
[Closed] Alfine - Santa Cruz Chameleon
Will an Alfine disk wheel fit in a Chameleon and could you use standard Deore disk brakes?
.and where is best place to get Alfine from?
Ta muchly
Posted : 20/07/2010 10:34 am
Based on seeing a few chameleons with alfines, I'm going to say yes.
Posted : 20/07/2010 10:46 am
Don't know, but I've run a Rohloff in both a horizontal dropout and EBB Chameleon OK.
Which Chameleon is it ?
With the horizontal dropout version the wheel moves in relation to the caliper mounts as you adjust the chain. You might, possibly, find you need a half link chain to get the disc lined up with the pads just right.
The EBB version avoids the problem.
Posted : 20/07/2010 11:15 am
It is horizontal. Wish there was another cheaper option as it is looking like circa £400 to put a hub rear wheel with disks on.
Posted : 20/07/2010 11:26 am
£400 ?
The bare hub's about £150 isn't it ?
A disc, sprocket, rim & spokes doesn't add up to another £250.
Posted : 20/07/2010 11:41 am
 gazc
got an excellent condition alfine wheel with all the fitting kit/shifter/cog etc in classifieds if you're interested? i've also got a 160mm shimano rotor that will fit it too. had it on my chameleon too funnily enough... email in profile if you're interested
Posted : 20/07/2010 12:49 pm
 gazc
MidlandTrailquestsGraham - need to add the shifter and fitting kit to your list (£35/£10 on their own!)
Posted : 20/07/2010 12:51 pm
gazc yhm
MTG I was looking at a pre-built wheel, can't be arsed to build myself
Posted : 20/07/2010 1:13 pm
 Del
i was going to say you'll get the wheel for about 250 quid, but get a decent rim and spokes, not a 4.2. you could use an adaptor if you don't already have a centrelock rotor. a2z do 'em, as do shimano i think.
the 11 speed isn't out for another couple of months.
Posted : 20/07/2010 1:17 pm
 gazc
DavidB mailed you back cheers 🙂
Posted : 20/07/2010 1:21 pm
