Alfine ratio ?
[Closed] Alfine ratio ?
4 Users
Question for you guys riding Alfine Hubs: Did you chose your gearing so you are mostly riding the 1:1 ratio-gear 5 on an 8 speed hub?
I've already got a Rholoff and they recommend using the 1:1 ratio- gear 11 on those for maximum efficiency.
Does the same principle apply with an Alfine?
Thanks,
Steve
Posted : 04/12/2011 7:09 pm
Empirically, it makes sense.
I have been drinking today mind.
Posted : 04/12/2011 7:11 pm
Isn't gear 11 on the Rohloff direct drive? I didn't think the Alfine had an equivalent.
Posted : 04/12/2011 7:12 pm
I have mine set up like that - its basically a commuter nowadays but if you gear it so riding along on the flat is 5th gear you have a decent range of gears above and below that.
5th on the alfine is 1-1 but apparently not direct - I don't understand that but then epicyclic gears confuse me
Cheers Guys,
Yes 11 on Rohloff is a direct 1:1 ratio, this is the same ratio as gear 5 on an 8 speed alfine.
1:1 is said to be the most efficient, whilst not discernable to me in terms of efficiency, you can certainly feel some difference through the pedals, but the wheels still go round.
Posted : 04/12/2011 7:21 pm
