Alfine hubs oil - g...
[Closed] Alfine hubs oil - geekery required
Has anyone been able to discover what the alfine oil is? You can get from shimano a tin of oil and an oil bath for them for IIRC around £60 but what is the oil?
Or can anyone make a case for what oil should / could be used.
Hypoid?
Synthetic engine oil,
3 in one?
ATF?
[url= http://www.castrol.com/castrol/multipleproductsection.do?categoryId=9014115&contentId=7027191 ]Some type of gear oil?[/url]
Ta
Posted : 15/03/2011 12:11 pm
I put synthetic gear oil in mine, has made it shift smoother, cant notice any less drag though.
Posted : 15/03/2011 12:22 pm
Assuming we are talking about 11 speed as the 8 doesn't run in an oil bath, is this correct?
Posted : 15/03/2011 12:24 pm
Its the only Shimano service for the 8 sp. Its an oil dip
Edit part 44 and 45
Posted : 15/03/2011 12:45 pm
Mines 8spd, gave it a petrol bath and a day to dry out first.
Posted : 15/03/2011 12:57 pm
i've been using ATF (not sure if it's a good match)
degrease + rinse hub
dry for 1 day
soak in ATF for 1 day
working well for me , I've checked and repeated this process and the oil has been clean after 6 months use
Posted : 15/03/2011 1:10 pm
The shimano instructions are not to degrease IIRC - their oil is supposed to work well with the remnants of the old grease.
Sounds a b1t weird tho
Posted : 15/03/2011 1:18 pm
hubstripping website is work a read.
they recommend degrease + cleaning, I filtered out the degreaser for reuse and it was full of aluminium dust + dirt which would have stayed in the hub otherwise
Posted : 15/03/2011 1:58 pm
I use EP80/90w gear oil and left the grease in. The only premature Alfine failure I have seen (one at less than 500 miles) appeared to be caused by corrosion of the roller clutch outer races causing the plastic roller cages to break up.
So I would conclude its not too critical what oil you use just so long as it is nice and oily in there.
I am tempted to try a thinner oil next time, like ATF (to reduce drag) but service the hub more frequently.
Posted : 15/03/2011 2:11 pm
