Bizarre centre-lock...
[Closed] Bizarre centre-lock adaptor question
[#2565616]
Does one exist which can be reversed, i.e. mounting the disc closer to the spokes?
I'd tell you why but it's a DIY project involving carbon fibre and the al-haterz would bully me.
Posted : 15/03/2011 12:08 pm
C/l for a 6 bolt?
could you not grind the mount down so that it moves the rotor inboard?
Posted : 15/03/2011 12:09 pm
I could but I don't have a grinder nor lathe (latter would make it easy I think) and of course it needs to be true.
I do have a drill and a black and decker work-mate, that could become a lathe of sorts...JOKE ALERT
Posted : 15/03/2011 12:16 pm
isnt it just alloy?
Random orbital sander, spare sheets and a vernier?
bodgetastic.
Posted : 15/03/2011 12:21 pm
Indeed...alloy dust everywhere!
Got 6mm to remove/adapt.
Posted : 15/03/2011 12:33 pm
Sounds like a time to get creative with a Hope disk (with the alloy spider) and some spacers
or maybe an XT would be simpler
Edit: I think I'd try the Shimano first - easier to do. Your own risk, natch!
Edit edit: a bit of alloy plate cut in a circle would make a better spacer and you could pass it off as an extra heat sink that's necessary because of your awesome braking skills 🙂
Posted : 15/03/2011 12:53 pm
Disc needs to move into hub epi not away from it...do you mean cut away at the back of the xtr rotor spline and spacer in front of it?
xtr too expensive for expt and it needs 140mm so gotta be 6-bolt rotor otherwise.
Posted : 15/03/2011 3:14 pm
Had more of a look at this - idea is put a disc brake on an audax bike and use it cx.
A 160mm rotor fitted on backwards with a 2mm bb spacer clears the stay and there's space for the caliper in there too. A 140mm wouldn't need the spacer and would be tighter but manageable.
[url= http://farm6.static.flickr.com/5171/5530422070_2eb6679e84.jp g" target="_blank">http://farm6.static.flickr.com/5171/5530422070_2eb6679e84.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/5530422070/ ]R0011080[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Tyre clearance may be an issue though (32mm tyre, 3-4mm clearance per side)
[url= http://farm6.static.flickr.com/5219/5530421504_82bbd5a918.jp g" target="_blank">http://farm6.static.flickr.com/5219/5530421504_82bbd5a918.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/5530421504/ ]R0011081[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
There's a prize for the first person to say "why not just buy a cx bike?"
Posted : 15/03/2011 10:32 pm
Tons of tyre clearance on an Amazon Al - and it's got disk mounts.....
Posted : 15/03/2011 10:36 pm
Posted : 15/03/2011 10:41 pm
:love:
Posted : 15/03/2011 11:00 pm
I'll get that on Saturday!
Posted : 15/03/2011 11:03 pm
cynic-al - Member
Yeah, drill out the existing locating pins, put spacer on inside and the disk on the inside of that. Then bolt it up.
But much better if you can avoid that faff.
Posted : 16/03/2011 12:35 am
Think I'm just gonna use a 160mm with 2mm filed off it or maybe a 140.
Posted : 16/03/2011 10:26 am
