I'm currently running an Alfine on a Kona Unit but want to swap to a horizontal dropout frame (Scandal). Is anyone is running similar, as I think it may be more faff than its worth?
The problem I forsee is keeping chain tension on the driveside as I wouldn't want to overtighten the hub nuts to keep it in place on an alu frame ๐
I made a special set of chain tugs but you could probably modify a suitable set (would need to be fairly chunky and flat - maybe BMX ones with a 14mm axle hole?)
My handmade tugs have a larger than normal hole so they fit on the outside of the anti-turn washers instead of the axle (about 19.5mm I think). Tug needs to be about 1mm thinner than the anti turn washer. Then use a big M10 washer between the axle nut and anti-turn washer to stop the tug falling off. I've sandwiched an o-ring in there to stop things rattling. All very neat and tidy and seems to work very well.
I used the anti-turn washers for vertical dropouts to get a different cable run (cable up the seatstay).
Hope that helps - I can mail you some pictures tonight.
Good idea! I was thinking of running the anti turn washer on the drive side over the top of a chain tug (suitably modified to accept the torque tab).
I have an Alfine on a Mk2 Chameleon, generally works fine. Think it has slipped once or twice on very short sharp climbs, when I haven't done the nuts up tight enough.
Good bit of kit so far.
