Advice to Cycling B...
[Closed] Advice to Cycling Beginners’ Long-distance Exploration
1 Users
[url= http://www.cycling-jerseys4u.com ]Cycling Clothing[/url]
A cycling beginner make a Long-distance riding should be in the summer, and the best choice is wearing streamlined and tight-fitting design of cycling clothing in short sleeves which will not increase the air resistance. The best target cycling pant should has real leather or PU leather cushion so that ensure the capability of cool function and wearproof. If the travel area was in the rainy season, we should also consider water-resistant function. Cycling jerseys of the market insulating both wind and rain are almost all quite expensive, riders can make a choice accoding to their finance condition. If cycling lovers did not prepare special cycling jerseys, especially riding pants, they can also use the high elasticity of the smooth shorts instead of cycling jerseys, and they should do not wear any clothing inside, and then daub Vaseline or other lubricants recurrent friction with the body parts. If the rider encountered bad cold weather, they can also be smart putting two old newspapers stuffed in the chest, excellent insulation effect.
For insulating wind and small flying insects, you should also wear riding glasses like Oakley. Clear lens for cloudy; dark lenses block ultraviolet light; light yellow lens is designed specifically for night riding.
Long-distance riding can also wear gloves, gloves are non-slip wear and help the rider to maintain the correct riding posture, and save your energy. However, I strongly do not recommend refusing using gloves, because gloves for the ride can avoid self-defeating.
Posted : 21/08/2012 3:54 am
