Advice needed on a ...
[Closed] Advice needed on a DealExtreme light: a bit too spotty, not floody enough
[#3570576]
Hi,
I bought one of these recently:[url= http://www.dealextreme.com/p/t6-waterproof-xml-t6-3-mode-1200-lumen-white-led-bike-light-with-battery-pack-set-904482510 ] http://www.dealextreme.com/p/t6-waterproof-xml-t6-3-mode-1200-lumen-white-led-bike-light-with-battery-pack-set-904482510 [/url]
It's wonderfully bright but the light is *very* spot focused, and although there's a reasonable halo, it'll be pretty difficult to ride offroad I think.
Any thoughts on how I could make it more floody? Can you get alternative reflectors, or are there any other tricks?
Posted : 16/01/2012 3:10 pm
Perfect, thanks
Posted : 16/01/2012 3:54 pm
 scud
Try some of the cloudy Scothcbrite tape on the lens.
Posted : 16/01/2012 4:16 pm
The lens does make the spot wider in a kind of letterbox shaped hotspot, but it is an improvement.
Posted : 16/01/2012 4:29 pm
I stuck the glow in the dark ring underneath the lens and reflector and found that helped a bit. Couldn't get scotch tap to work that well
Posted : 16/01/2012 5:00 pm
