Is it possible to change the 160mm travel version of this fork to 170mm or vice versa?
Looking at a cheap mega and wondering what the options are with the fork on the pro build- i.e. if I want to slacken it off for example could I increase the travel.
Posted : 04/09/2012 9:41 pm
You need to change the air spring internal to 170mm spec as you can't spacer these down like the older soloair systems. Damper unit (rebound assm. should take 170mm you only need to change that if you go to 180mm.
๐
Posted : 05/09/2012 6:14 pm
