Adjusting compressi...
[Closed] Adjusting compression on Revs, without using the poploc??
Bought some Revs for my Soul but don't really want to use Poploc - just crowds the bars out. But without it I don't seem to be able to adjust the compression damping. The manual says turn the dial on the right-hand leg, but there's just an allen key fitting. On my Pikes you can turn the blue adjuster but it's just not an option on the Revs.
So any idea how I can play around with it other than the +ve/-ve air chambers or fitting the poploc?
Ta
Posted : 14/03/2010 9:06 pm
2 options. Buy a poploc adjust. Or alter your compression damper (either unclip the internal spring, or replace with a proper non-poploc unit)
Posted : 14/03/2010 9:16 pm
or put a small bit of gear cable through the poploc and adjust it, tighten it and leave it.
hey presto compression adjusted and no junk on the bars.
Posted : 14/03/2010 9:56 pm
