A question about hu...
[Closed] A question about hubs and Torque Caps
I'm building up a new hardtail using a mix of new parts and spares I already have. I have some new Pike Ultimates to fit that are Torque Cap compatible and I presume because of this, have a bloody great 30mm(ish) recess in the dropouts.
The wheel I'm fitting is a standard E thirteen (boost) from another bike and has 15mm end caps that fitted a Fox 36. Soooooo, can I fit this as is? Obviously it will be trickier to line up with the hole/maxle as it won't be snug with the recess, but will it be OK otherwise? Or are Torque Caps a must?
Any advice appreciated. Ta 🙂
Posted : 01/02/2020 1:29 pm
It'll work just fine. As you say, just needs a bit more care when lining it all up.
Posted : 01/02/2020 1:31 pm
It will be fine without the torque caps.
Posted : 01/02/2020 2:04 pm
Yep, wife's orange came with torque cap hubs but normal 15mm hub.
Swapped the wheel over as it became a pain when putting the bike in the car.
Posted : 01/02/2020 3:04 pm
I use these, work perfectly and much cheaper than proper torque caps.
https://r2-bike.com/NEWMEN-TC-Adapter-for-Forks-with-Torque-Cap-Drop-Out
Posted : 01/02/2020 3:44 pm
I've a set of those adapters spare if anyone needs a pair. About £8 posted (I ordered two sets from Bikester due to steep postage)
Posted : 01/02/2020 4:15 pm
Thanks chaps!
Posted : 01/02/2020 8:19 pm
