I've got end caps to convert a front hub to 100mm x 9mm thru bolt, only options I can find for the bolt itself though are QR versions e.g.
https://www.superstarcomponents.com/en/ultralight-alloy-9mm-front-qr-through-axle.htm
Does anyone know if there is a simpler hex head bolt version of these? Hadley used to do one I think
https://www.balleracing.com/hadley-front-hub-thru-bolts/hadley-thru-bolt-9mm-x-100mm
Anyone got one of these knocking around they're not using now they've moved onto a more sensible standard?
Ta.
The RWS is effectively a bolt with an inbuilt handle/tool that can be repositioned.
The 12 and 15mm thru-axle versions have removable handles, but the 9mm one doesn't unfortunately.
