Is it possible ? or do I need to invest in a new chain as well... ??
Sorry if I'm being stuuuuupppppid..
Posted : 02/06/2010 10:25 am
Nope, you need a specific chain.
Posted : 02/06/2010 10:26 am
pretty sure thats a no, narrower chain on 10spd
need new chain.
Posted : 02/06/2010 10:29 am
I would guess you would have to change Cassett, rear Derailleur, chain and probably the front chain rings as well.
Although I may be corrected on this in a few moments..... ๐
Posted : 02/06/2010 10:31 am
Could you just change the jockey wheels on the derailleur?
Posted : 02/06/2010 10:35 am
Jockeys and rear mech will be fine, and the rings almost certainly will be.
Chain does need doing. You can, however, run a 10 speed chain on a 9 speed block.
Posted : 02/06/2010 10:49 am
That's cool... new chain it is then.....
Posted : 02/06/2010 10:59 am
Do 10 speed chains weigh less NJEE20???
Posted : 02/06/2010 11:03 am
Yep, the difference between the X9SL and X10SL appears to be a whopping 2g!
Posted : 02/06/2010 11:24 am
