853 inbred - what f...
[Closed] 853 inbred - what forks is it corrected for?
 s
Sure someone here might be able to help.
I have been offered a second hand 16' singlespeed frame, one of the 100 limited edtions. Ita a frame only sale and was running RC-31's & the owner is not sure?
Does anyone know what its corrected for?
Would Reba 120mm be ok?
Ta.
Posted : 16/05/2011 2:48 pm
The orignial inbred and the 853 SS version are designed for 100mm forks
Posted : 16/05/2011 2:52 pm
 s
Thanks weeble
So 120mm might be a bit much ๐Ÿ˜‰
Posted : 16/05/2011 2:59 pm
Built for 100-130mm forks
Works best at 130mm with gears but a bit less on a SS will climb better
I had 140mm on mine for most of the time
Posted : 16/05/2011 3:03 pm
 sv
120s on mine when I had it. Seemed to ride fine!
Posted : 16/05/2011 3:06 pm
 s
OK thanks PP,SV
Bit of a numpty question, sorry in advance:
Going from 100mm to say 120-130mm on that frame, will it make the handling twitchier?
I always get a bit confused which way makes the handling twitchier?
Posted : 16/05/2011 3:11 pm
The earliest Inbreds were (according to my mate Pete, who had one of the first 853s) horrid with anything over 80mm. He ran SIDs at about 60mm.
Posted : 16/05/2011 3:39 pm
 Del
the 100 Ltd editions from 3 years ago(ish) were for 100-130mm fork. mine runs dandy at 130mm, ta very much. longer will make it more slack ( a bit ).
Posted : 16/05/2011 4:23 pm
The 853 limited edition ones were the Mk2 geometry, Personally I wouldn't go below 115mm, but if you like 'em fast steering 100mm is fine. I found 130mm perfect. ๐Ÿ™‚
Posted : 16/05/2011 5:07 pm
Same 130mm felt good for me, was using Talas at the time so could wind it up and down, also don't forget they have a very short headtube so don't worry too much.
Posted : 16/05/2011 5:16 pm
I'm happy on my Mk2 Inbred with 425mm rigid fork. Have tried the Reba at 100 and 85 travel, and I much prefer it at 85mm, but what do I know?!!
125 revs on mine is perfect - gotta say I love this bike
Posted : 16/05/2011 5:39 pm
Stick 130mm on and see what you're missing! ๐Ÿ™‚
Posted : 16/05/2011 5:46 pm
