7 speed cassette an...
[Closed] 7 speed cassette and mech with 8 speed shifter. Can it be done?
As above really, is the gap between the sprockets the same, such that the 'pull' of the shifter will move the derailleur the right distance?
If so, I guess start indexing with the shifter in 7, and 8 will be a redundant click, with the limit screw stopping the mech dropping the chain off the bottom of the cassette?
Cheers, all advice gratefully received.
Alex
Posted : 03/09/2009 10:58 pm
Yep, that'll work fine.
Posted : 03/09/2009 11:11 pm
 Ogg
Spacing is 0.2mm different from 7 speed to 8 speed by the looks of it
http://www.sheldonbrown.com/k7.html#spacing
so you should only be out by upto 0.6mm in 1st and 7th gear so sounds do-able.
No practical experience though!
Ogg
Posted : 03/09/2009 11:13 pm
what ^ they said (especially Ogg)
make the central sprocket the one that lines up perfectly, not the smallest as you might for perfectly matching shifter
Posted : 03/09/2009 11:34 pm
OK, so index from the middle, and it might get a bit jumpy at the extremes. Ta.
Rolfharris, have you any experience?
Alex
PS, Ogg is that you?
Posted : 03/09/2009 11:37 pm
Done it an dyou have to accept a little skip in one gear 4 th in mine but a half click of old STI shifter sorts it
Yes it can be done index is a bit more fidllely (spell?)to get it working OK.
Posted : 03/09/2009 11:41 pm
 Ogg
Yes it is - cheers for the loan of the room last weekend!
Posted : 05/09/2009 9:18 am
No worries, and thanks for the spot-on advice. Gonna see if I can blag a 7 speed unit from the parts bin at the office.
A
Posted : 05/09/2009 4:29 pm
