51mm or 56mm chainl...
[Closed] 51mm or 56mm chainline
Hi
Just received my frame (second hand specialised fsr comp, circa 2008) and I have a quick question was just about to order up a BB (73mm shell size) but have seen they are 113mm or 118mm in length and suit chainlines of 51mm and 56mm, so I need a little guidance please
Thanks
Mike
Posted : 03/05/2011 6:50 pm
What cranks are you running? 50mm is closer to what you want.
Posted : 03/05/2011 7:24 pm
Hi Onzadog
Was considering truvativ ones, I had rukition on my old Marin which were ok
Posted : 07/05/2011 6:30 pm
a 113mm bb will get you nearer to 50mm, but if you find that chainring too close to the chainstays of the frame and suffer a lot with the frame from chainsuck a 118mm bb would give you a little more clearance and will provide a chainline nearer 52-53mm (its 5mm wider so only 2.5mm extra on both sides)
Posted : 07/05/2011 7:46 pm
Ta Chunky
Posted : 08/05/2011 12:09 am
