456 Evo carbon??
[Closed] 456 Evo carbon??
2 Users
A problem I can't seem to find an answer. It's probably simple but on this new frame the head-tube is apparently longer than the original carbon. My forks are over 200mm steerer and I run a few spacers on the 18" frame.
The new frame would be the 20" as I'm running a lot of seat post on the 18. I assume the forks would be fine and I can use the current headset on the Evo?
I did contact on one but he only said the headtube is longer than the older one and has no clue by how much or what.... Must have been work experience day 😆
Regards scott.
Posted : 08/09/2014 8:21 pm
All the frame measurements are on the On-One site under sizing (under frame only). The head tube on the 20 inch is 125mm.
Hope that helps.
Andy
Posted : 08/09/2014 8:34 pm
I never thought!!! Thanks seems it's only 5mm.
Posted : 09/09/2014 9:53 am
