30.9 to 31.6 shim
[Closed] 30.9 to 31.6 shim
4 Users
 spev
Anybody put a 30.9 post in a 31.6 frame and used a coke can shim? Is there a better way that i've not thought of? Got 2 frames, fancy a dropper post but dont want to fork out for a Gravity Dropper (which is easier to shim from 27.2)
Posted : 16/01/2011 2:52 pm
 Ewan
I was going to do this as I have a dropper post with a chumba 31.6mm frame. However following a little bit of reasearch I found that USE will make you a custom shim for 6 quid. Bargain.
The USE part code is SS30-9-31.6
USE don't deal direct with the public so you'll need to get your LBS to order it. I got evans to do this and it took 4 days to arrive.
The main thing that makes it better than a coke can is that they machine a lip on to it so you can't actually drop it down the tube.
Works perfectly and saved me getting a second dropper post (and/or messing round with coke cans).
Posted : 16/01/2011 3:21 pm
I bet that's delicate. 0.35 mm thick.
Posted : 16/01/2011 3:30 pm
 Ewan
Er, 0.7mm thick. It's about twice as thick as a dr pepper can by my reckoning. Seems robust enough - i'm just going to leave it in the frame afterall.
Posted : 16/01/2011 3:34 pm
0.7 is the difference in diameter. The wall thickness would be half that.
Like you say, once it's in the frame it will be fine. Just delicate getting it there.
Posted : 16/01/2011 3:43 pm
 Ewan
Ah good point! That's embrassing!
That said, I wasn't particularly delicate. I shoved it in. Put post in. Jobs a good un. I'm not known for taking appropiate care!
Posted : 16/01/2011 3:48 pm
Ah, a special shim from the private stock of Baron Alfred Krupp, who had to sell it at a great sacrifice.
Posted : 16/01/2011 4:23 pm
 spev
lol, i'll get onto USE in the morning then 🙂
Posted : 16/01/2011 5:23 pm
