£3 cable mudproofin...
[Closed] £3 cable mudproofing!
4 Users
[url= http://www.wiggle.co.uk/transfil-gear-cable-waterproof-kit/ ]H E R E [/url]
[img] ?w=350[/img]
The ferules have little tubes which poke through the cable stops and the skinny plastic tubing covers the inner between these points.
I've fitted this little kit to my new frame and think it's really going to help in the clagg. I think it's just the bits that go with inner & outer to make a Mudlovers kit.
There was more than enough to do my Trance and although it requires a little patience, is fairly straight forward to fit.
Posted : 21/12/2011 11:43 am
Yep, I have used these for years. They make the expensive kits look like a bit of a joke.
Posted : 21/12/2011 11:54 am
I have a set I have never used in a box somewhere.
I've never really understood why a lot of companies still insist on interrupted cable runs.
Un-interrupted with a cable oiler or two.. best thing in the world.
Posted : 21/12/2011 11:57 am
I had uninterrupted on my last frame and didn't want to drill the new one so found these. I heard one reason companies still use stops is weight!? I think it would be good to offer the choice, a full length ring with a split and a little insert to turn it into a stop if you're that way inclined.
But yes, I agree: full length FTW!
Posted : 21/12/2011 12:05 pm
kind of makes the goodridge and gore kits seem stupidly expensive! adding to shopping list for second bike.
Posted : 21/12/2011 12:15 pm
