2x9 chain length
[Closed] 2x9 chain length
Giving 2x9 a go, last couple of jobs left including fitting the chain.
Good job I'm not afraid to ask stupid questions - what length? Big to big + 2 links doesn't 'feel' right as it'll be on that ring a fair bit and could be running across the whole block.
Thanks
Posted : 18/05/2010 7:33 am
It might not feel it, but its fine, add an extra link if you fancy though.
Have you upped to a 36t ring at the front? I would bare in mind, you might want to up the ring from 32t to 36t at some stage.
Posted : 18/05/2010 7:53 am
Yup 36 ring up front, still using the old long cage RD though, hence why I wondered if chain would be a bit short.
Posted : 18/05/2010 11:51 am
what ratio are you running?
I have a 11-34 block - i am thinking 24/36 up front?
Posted : 18/05/2010 11:56 am
I've got 24/36 and 11-34 and it seems spot on for mtbing.
You can see that the chain is fairly taut even with 36 and middle of the block here - Big/Big +2 is fine.
Posted : 18/05/2010 11:59 am
I did big-big with the suspension fully compressed, which needed 2-3 more links than simply big/big. That is running a 42/28 and a 11-34 at the back (2x9).
Posted : 18/05/2010 12:17 pm
