29er rigid fork mea...
[Closed] 29er rigid fork measurements - advice please
[#5662909]
Hi Guys
I'm currently using rigid steel forks on my 29er unit single speed. I would like to put monocoque carbon forks on. Obviously the niners are the ones i'd like but not in my price range. On-one do these
http://www.on-one.co.uk/i/q/FOOOSCF4709/on_one_monocoque_straight_steerer_carbon_fork
Now my delema is this..... as I understand it 29ers are 465mm. These are 450mm. Would I notice any difference? Can 15mm really make any noticeable difference ?
Sorry if this has been asked before.
Posted : 04/11/2013 7:38 pm
 mokl
Remember you're looking to emulate the A-C of suspension forks when sagged, so depending on what forks your frame is designed around these will probably be fine. For example I put some 460mm rigid forks on my Dialled PA to try and recreate the handling of the bike with 120mm forks fitted - that's a 26" wheel. Hope that made sense!
Posted : 04/11/2013 8:13 pm
Isn't it 10mm = 1 degree of head angle change? ish
Posted : 04/11/2013 8:14 pm
 mokl
Sorry, just re-read and you've already got rigids on there! D'oh! FWIW I suspect you will notice little difference although it may marginally speed up the steering.
Posted : 04/11/2013 8:15 pm
Can't see it being that different to putting smaller tyres on. Think the unit has a head angle of 70, might make it 71 ish. But quite a few 29ers are 72 anyways. Seat will come forward a touch too I suppose. Dunno if it would cause structural issues, but be surprised.
17mm = 1 degree.
Posted : 04/11/2013 8:17 pm
I think that makes sense to me. Slight 1-ish degree headtube angle change, would b 15mm lower at front.? Am I reading it right ?
So should be OK then.
Posted : 04/11/2013 9:09 pm
