29er MTB wheels tha...
[Closed] 29er MTB wheels that fit 11 speed shimano road cassette
Hi,
Has anyone found a 29er Wheelset that fits a shimano 11 speed road cassette? the reason i ask is i have 105 11 speed and discs with a 135 hub spacing and 15mm front axle on my CX bike and want to upgrade the wheels.
I know hope do an 11 speed freehub conversion, but their 29er wheelsets are a bit too wide for CX and i don't like the rims on their road disc wheelsets using the Pro 2 hub.
If no one can suggest an alternative, i'll get some built up, but just want to see if there are any suggestions before i bite the bullet
Posted : 06/11/2014 2:48 pm
Anything with DT240 (or 350 or 180) hub internals - so Bontrager etc, as well as handbuilts. Recent Pro2s with 40t ratchets - build onto narrower rims if you don't like their options.
Mavic factory wheels should work (or be convertible) too.
Posted : 06/11/2014 2:51 pm
If it helps I have found crests to work very well with cyclocross tyres
Posted : 06/11/2014 11:21 pm
Why does it need to be a mountain bike wheelset?
Mavic ksyrium pro disc are nice (if a bit spendy)
Posted : 06/11/2014 11:39 pm
 mboy
What rims are you after?
Speak to a custom builder maybe...? I'm just about to build my own up for my new winter bike, there's increasingly more choice in the disc brake road rim market now...
Posted : 07/11/2014 12:10 am
I've built up some hope pro 2 evo hubs on stans crest rims which have been great so far.
You can get the hope hubs with the 11 speed body prefitted now too.
Posted : 07/11/2014 8:37 am
I have a barely used rear wheel only if its any use. Pacenti sl23 all black rim on novatec 712 11s hub 28 h built with black Sapim DLite spokes/alloy black nipples £100 squids.
Posted : 07/11/2014 9:11 am
Crests aren't too wide for cross, but Hope will also build a couple of Hoops with Stans Alpha on either XC6 or Pro 2 Evo. Could be worth a look.
Posted : 07/11/2014 9:17 am
I was just looking at off the shelf MTB wheel sets as my cross bike has a 15mm thru axle front, which none of the road disc setups have. I know Hope can be converted easily, was just looking at off the shelf options really.
Will probably get some Stans Alpha 400 rims built up 28 spokes to Pro 2 evos's with the 11 speed freehub.
Thanks all
Posted : 07/11/2014 10:42 am
Possibly cheaper to live with the 32h Hope Hoop version I suspect. Hoops tend to be good value compared to self builds.
Posted : 07/11/2014 4:05 pm
Cost isn't the issue, i can get wheels built up super cheap and parts on trade, so not an issue, just looking for a quick decent option.
I'll just go with a build of my choice.
Cheers all
Posted : 07/11/2014 6:03 pm
 jonk
I'm on crests on pro2 evo 40T on my CX bike, with an 11sp ultegra set up. Apart from the front wheel needing a bit of adjustment (hope hoops) its has been excellent.
Posted : 07/11/2014 7:20 pm
