29er front disc whe...
[Closed] 29er front disc wheel for road commuter? - options?
I about to fit a discfork to my 700c commuter and need a front wheel to fit. I'm aware of the Mavic Speedcity but I'm thinking that a 29er wheel will be fine too, as long as the rim isn't too wide.
Anyone spotted any good deals?
They'll be running 28mm road tyres.
Posted : 18/11/2011 3:59 pm
or put another way, tell me about cheap 29er wheels with QR hub.....
Posted : 18/11/2011 4:03 pm
Build your own? XT or Deore hub and an Open Pro rim and spokes of your choice. Works for me (one one bike - Speedcity's on the other.... they are really nice :-).
Posted : 18/11/2011 4:09 pm
I bought a pair from Merlin - cheap n nasty hubs but fine for road use, £60 a pair inc VIP discount. At that price you can price in a rebuild to a nicer disk hub in a year or two.
Haven't got around to installing the cross tyres I was going to use (32mm), but I think 28mm might be a bit narrow for a 29er rim.
Posted : 18/11/2011 4:16 pm
just found this for £107
http://www.evanscycles.com/products/hope/pro2-evo-no-tubes-ztr-crest-29er-front-wheel-ec027435
- the Crest and Arch rims look very similar on the NoTubes site. Is one better suited for road tyres...?
Posted : 18/11/2011 4:19 pm
I currently run Mavic A319 rims which are listed at 25mm wide, which puts them at the same width as the 29er Arch and Crest rims (24.4mm) so they should be okay.
Posted : 18/11/2011 4:22 pm
Both/all a bit overkill for road use IMO - esp on teh front.
Posted : 18/11/2011 4:27 pm
yeah, maybe.
The thing is that most (all?) disc hubs are 32h so even if you try a lightweight build of, say, a Hope Evo hub on Open Pro the Open pro rim is a full 435g, whereas the Stans Crest is only 380g, so the Hope/Crest 29er wheel may well be lighter than you could handbuild something anyway....
Posted : 18/11/2011 4:34 pm
Ah fair enough - I forgot the crest is their lightest 700c rim (bar the alpha).
Posted : 18/11/2011 4:39 pm
If it's rim weight your worried about, go for Halo Aerotracks - at-or-just-under 400g a pop and can be had on Ebay for about £20, or £30 retail (again, currently using these on a 700c disc bike and, despite the lack of eyelets, they have been absolutely fine, stiff and true for over a year).
Mavic A319 disc rims laced to Shimano Deore disc hub should do ya !
Posted : 18/11/2011 4:49 pm
Mavic A317s on Deore disc hubs? :mrgreen:[url= http://singletrackworld.com/forum/topic/fs-mavic-a317-29er-wheels-on-deore-disc-hubs-700c ]My wheels?[/url]
Posted : 22/11/2011 3:04 pm
Oh and I think 319s would be too wide for 28mm tyres.
Posted : 22/11/2011 3:05 pm
I run A319s at the moment and they're fine on 28s
Posted : 22/11/2011 3:11 pm
Watch out if you go stan's - from what i understand you can't run road bike pressures in them, they are only rated to about 50psi with a 1" wide tyre because they may blow off with the less aggressive bead.
Posted : 22/11/2011 5:02 pm
turns out that max pressure thing only applies to tubeless, you can go higher with tubes.
Posted : 23/11/2011 9:11 pm
Like this:
XT hub, Swiss champ spokes, 29p each at Rose Bikes.
Posted : 23/11/2011 9:18 pm
