29er Frame with non...
[Closed] 29er Frame with non tapered steerer...
What's available?
Steel or aluminium.
Not custom.
Ta
Posted : 15/08/2016 10:31 am
If you have old straight steerer forks you can make them fit pretty much any frame... Why limit future fork purchases?
Posted : 15/08/2016 10:32 am
As above tapered forks seems easier to source than straight. Id go tapered and space current fork to fit
Posted : 15/08/2016 10:35 am
SIngual Swift still has a straight steerer I think.
Posted : 15/08/2016 10:42 am
Salsa El Mariachi will take both.
Posted : 15/08/2016 10:45 am
Gen 1 scandal? I just sold one, there's still a good few out there and they're really good... And cheap!
Posted : 15/08/2016 10:54 am
As above, probably just the Swift if you want to buy one new.
Second hand there's probably a bigger choice, but even so 29ers and tapered steerers came into the mainstream within a year or so of each other, so your choice will be limited somewhat to a few older frames.
Any particular reason why it can't be a tapered frame?
Strictly speaking the El-Mariachi (an others) isn't tapered, its 44mm, which takes a internal headset for straight steerers or an external one at the bottom for tapered.
Posted : 15/08/2016 10:58 am
