26mm flat ended soc...
[Closed] 26mm flat ended socket, where from?
Can't find a flat faced 26mm socket to remove the top caps off my fork legs, adjustable spanner does not have enough purchase, any ideas where I can get one? Alternatively, with only a 6" angle grinder at my disposal can I grind the face of a normal socket flat?
As an aside, what is it with American companies using these dodgy sizes? Ford use 7mm allen bolts on their brakes, standard sizes are 6 and 8, Fox use 26mm top caps, standard sizes are 24, 25 and 27, muppets.
Posted : 08/04/2009 9:22 am
Just grind it down.
6" angle grinder will be a piece of piss. I've done them by hand before and it ain't that difficult.
Posted : 08/04/2009 9:26 am
motor companies use odd sizes to stop people doing their own maintenance.
another example Renault like to use the 15mm socket - made of merde du cheval rockee
Posted : 08/04/2009 10:07 am
Your right 26mm is an odd size it might be an AF American Fine imperial size that measures to 26mm. You might be able to get a 26mm box spanner.
Posted : 08/04/2009 10:36 am
You need a box spanner
Posted : 08/04/2009 10:38 am
Go to a proper tool shop, they'll get you one in the correct type easily, but you'll still have to grind the face flat though.
Try tooled-up.com, part no.15315. Don't be tempted to go for a wall drive if they're for Fox forks either as it loads up on the thin part of the nut and may damage it.
Posted : 08/04/2009 12:39 pm
pantsonfire is right, i use a 1" AF socket
Posted : 08/04/2009 1:03 pm
