230 x 65 shock on a...
[Closed] 230 x 65 shock on a 2018 intense carbine designed for 230x60?
[#10978910]
Thoughts?
Currently have a RT3 and seen an RC3 for a good price however its 230x65 so i figure i'll get 12mm ish extra travel. Anybody ever done it on a carbine?
Posted : 26/12/2019 11:15 pm
It's just a spacer which can be removed making your current shock 65mm stroke if required. Possibly not a DIY task though..
Posted : 26/12/2019 11:28 pm
Not done it, but it'll only give you that 12mm if you bottom out, can't see anything fouling out, your BB will be lower, but you can counter it a bit by adding some volume spacers perhaps?
Posted : 26/12/2019 11:47 pm
You'll need to make sure the shock linkage doesn't clout the frame on full compression.
Posted : 26/12/2019 11:54 pm
Just check your back end can go the extra distant without interference issues like tyre buzz on the saddle, I did something similar years ago with a kona and the linkage hit my Hope seatclamp, lucky I checked first with the shock off.
Posted : 26/12/2019 11:57 pm
really depends on end rate which is rarely flat and often quite rising meaning might get into trouble fast.
Posted : 27/12/2019 1:00 am
Its tyre to seat tube that will hit, I run 62.5mm stroke. You should be ok with 65mm but may find tyre rubs seat tube on full bottom out
Posted : 15/02/2020 6:20 pm
