Picked up a little Hotrock for yunki MkIII but it's got BMX bars with a mahoosive rise which are gonna be a bit daft til he grows a bit more..
Where can I see a selection of cheap bars with a 22.2mm clamp size?
It's got a 1 1/8 inch ahead steerer but I don't really want to fork out on a new stem as well
Motorbike bars (ebay searching) look right, but will need cutting down so much you'll be in the rise
I'd just pick up a cheap stem and get it on a standard set
what sort of bar?
Flat, riser, width?
as Mork said, 25.4mm or 31.8mm stems are very cheap then just get a cheap riser.
err... a selection of cheap bars with less than a mahoosive rise reggie..
for a kids bike so not too wide, he's three 🙂
ti?
(just remove the shim...)
a cheap 25.4mm stem + old MTB bar will be sub £20 though...
Thanks 🙂
Yeah, I'm thinking if I go down that route a little 'fixie' bar might be the way..
The oe bar is 10-degree backsweep, 4-degree upsweep, 115mm rise and 520mm wide
EDIT: LOL Ti!! That's serious bling 🙂
Made out of cro-mo steel so not very light but they're only £14.99
aHAH!
Thanks carlos.. We have a winner
It's even available in the right colour 🙂
[url= http://outlet.upgradebikes.co.uk/Outlet/Handle-Bars/Atomlab/Atomlab-General-Issue-Bar-1 ]Also available direct from Upgrade[/url] 🙂
