2.2 Nobby Nics on X...
[Closed] 2.2 Nobby Nics on XT wheels...
[#7340649]
They should fit?
Maximum tyre size for XT wheels is 2.2, so why can't I get the sodding things to squeeze on? Gave up and came back indoors before I chucked the wheels across the garage.
And breathe.....
Retro 26" size BTW, with Luddite inner tubes
Posted : 19/09/2015 9:34 pm
Will attempt it again when I get back from a road ride..... 👿
Posted : 20/09/2015 8:27 am
I had trouble fitting a pair of Nobby Nics onto my Hope Tech XC rims, they were very tight and needed a lot of washing up liquid to finally get them on. Just think they come up tight compared to others.
Posted : 20/09/2015 11:41 am
As above. Some Schwalbes can be a bit tight.
Contrastingly, I've got a Nuke AM rim that a Dampf is a fairly baggy fit to seat on, and an old set of Sun's that are sods to get anything on they're so tight.
Plenty soap and a deep breath. The 2.2 spec on your wheels is more to do with advisable width to avoid lifting beads under corner loads than getting a tyre to mount on the rim, BTW.
Posted : 20/09/2015 12:57 pm
Always start and finish on the [u]opposite[/u] side to the valve.
Amazed at how many people don't do, and or know this.
Posted : 20/09/2015 2:52 pm
I'd never heard about starting opposite the valve.
Will attempt that, while armed with washing up liquid.
Posted : 20/09/2015 4:04 pm
Doesn't seem to matter which way I try and coax the tyre on, or how much washing up liquid I use.....
It occurs to me that if I struggle so much to get the tyre on in a warm dry garage with no real time pressures, these probably aren't the right tyres to be trying to fix a puncture in the dark in the pishing rain.
Anyone want to buy an unused pair of Nobby Nics, one still in the box? 🙄
Posted : 20/09/2015 6:59 pm
