20mm thru axle to q...
[Closed] 20mm thru axle to qr dropout conversion kit
Hello,
i have just designed and developed a conversion kit to convert a 20mm thru axle fork using pinch bolts to qr dropouts
I have put this product in the seller section but i'm using this as a chance to get my product out there
A full advert and details can be seen at: http://www.pinkbike.com/buysell/903301/
Any questions and comments can be answered either through pink bike or email
on_fire90@hotmail.com
Thankyou
Callum
Posted : 14/08/2011 11:33 pm
What's the point of this
Posted : 15/08/2011 6:29 am
Is it technically a QR if you have to bolt it in. Isn't it just a 9mm bolt through adaptor?
Posted : 15/08/2011 6:48 am
I have 2 bikes. One with a regualr QR and one with Maxle (although maxle isn't comaptible at the moment) It would be handy to be able to swap wheels over without the need to need to change tyres etc. Handy also if you bought a new bolt through fork and didn't have the funds to buy a bolt through wheel, perhaps.
Posted : 15/08/2011 8:24 am
cruzheckler - Member
It is typical STW to take anything that anyone has done and pour unconsidered scorn over it.
OP well done, useful for some I am sure.
Posted : 15/08/2011 8:28 am
^^ this
Got some Society forks a while back that came with an adaptor like this. Very useful.
Posted : 15/08/2011 8:59 am
Pretty standard answer from you there cruzheckler.
^^ pretty handy for some people ill bet..
Posted : 15/08/2011 9:03 am
Probably not impossible to make it Maxle compatible too - just thread it on one side.
Posted : 15/08/2011 9:07 am
mac - shut up, its a valid Q, why when you have huge stiff 20mm forks would you want to run it with a spindly 9mm wheel?
Posted : 15/08/2011 9:14 am
This is good. No use to me, but a good idea and a lot more inventive than the usual idea of rebranding Taiwanese parts.
Hope you sell a few, sort out maxle compatibility and maybe come up with a few other good ideas.
Not everyone can afford to replace fork and wheel set at the same time.
You trash a 20mm wheel, but you've got a spare qr wheel- you're still mobile.
Posted : 15/08/2011 9:16 am
fury muff
Posted : 15/08/2011 9:17 am
You may as well ask, "What's the point in reducer headsets?" Yeah, you have a point about stiffness, but when there are so many different 'standards' coming in and out all the time, adapters like these fill a very useful function.
Posted : 15/08/2011 9:18 am
First thought on seeing post was bike forum being spammed to promote trader. But its such an original simple genius idea I say chapeau and if you do a 15mm version and can crack the maxle market you deserve to reap the rewards!
Posted : 15/08/2011 10:07 am
Yup if you can do this for 15mm Maxle Lite, I have a spare pair of wheels!
Posted : 15/08/2011 10:10 am
actually just what I need so I can order new 20mm forks, run the old wheels why I build a new 20mm wheel. sweet.
Posted : 15/08/2011 2:38 pm
A better question would be if you have sorted it with Mark, Chipps and co. to put a trade ad on the forum.
I'll have 10pence that you haven't.
Posted : 15/08/2011 2:50 pm
TBH I cannot see how he is making much/any profit ..
Posted : 15/08/2011 2:59 pm
Ok so a wild veriety of comments...
Basically it is as vinnyeh and benjim said it just offers a wider compatibillity.
I have had some questions about stiffness but due to the captivated skewer design it is like using a smaller thru axle, offering far improved stiffness over the standard QR.
Currently for maxle systems the bushes would need to be pressed in, and thus pressed out again for removal. As this is not a practical solution i am currently developing a kit to get around this problem.
As for 15mm axles as i only have access to 20mm forks i cannot design it as yet but as there has been interest in this i will also focus on this market
just to clarify i'm a 22 year old engineer, with ideas for problems i've come accross when out on my bike, not some spammer or business man trying to make it big
un helpful comments are not welcome, you know who you are...
cheers and keep the suggestions coming!
Posted : 15/08/2011 3:12 pm
toys19 - Member
At£30 a pop?
Posted : 15/08/2011 3:20 pm
