I’ve cracked the body of my remote lockout whilst securing it to my bars so I need to get a new one.
Can’t find them anywhere. It’s a 2018 one I think, a 2 position one.
Does anybody know where I can get one from ?
Silverfish says they are due back in stock today, so perhaps give them a ring.
If you've overtorqued the clamp and split the area the bolt goes into, you may be able to bodge it with a longer bolt and the 'female' bit of a two-piece chainring bolt.
Not sure exactly if I used the bit you mentioned but with a “bit” from an old chain set I had in my toolbox and a longer bolt I have indeed managed to botch it.
Thank you very much for your advice, saved me £50
Sounds like you broke it exactly the same as me, and fixed it the same way! Mine is still holding up well a couple of months later, so hopefully it will be the same for you. Glad my bodging was finally of use to someone!
