2017 Reverb stealth...
[Closed] 2017 Reverb stealth Cold no return /slow
I dragged my Whyte you today for a day around Llandegla after its 4 week off duty, when i checked everything last night everything was good but after 30 minutes of so today the return on the reverb was beyond slow and at one point it stayed down . After the trip home in the car it seemed a little better so my guess was the temperature ,so decided to so fro a quick spin once I got home , after 8 miles or so i dropped the post for a run down and it stayed there for the remaining 8 miles home ..not the best ride ive ever had knees in chest.
Is this a fault or will a bleed be in order? seems strange that it suffers with this kind of problem where my cable operated Lev has been out in minus 5 + conditions and never caused a problem
Posted : 27/12/2017 8:39 pm
Mine did that, I queried it in several places and basically got a unanimous 'they all do that, sir' style response 🙁
Posted : 27/12/2017 8:47 pm
Yeah,just a simple bleed should be needed-somehow you have compressible air in the non compressible hydraulic fluid that exacerbates things as it get colder.
Posted : 27/12/2017 8:48 pm
As the post is what maybe 4 months old and seen less than 40 hours use i am worried thats its a fault I will try a bleed and check pressure in the morning ..fingers cross
Posted : 27/12/2017 8:57 pm
I had the same issue with mines, in the end I converted it to cable using the bikeyoke dehy. I’ve not had a single issue since
Posted : 27/12/2017 9:17 pm
Euans2 now that looks very interesting
Posted : 27/12/2017 9:59 pm
Worth noting that in Fat circles the phenomenon is well known. If the post behaves normally at normal temperatures you may be chasing a non existent fault. How cold was it out at Degla today?
Posted : 27/12/2017 11:34 pm
Happened to mine three (?) weeks ago in the last cold spell and I remember the same thing happening last winter. That was the last straw for me, not sure what was the first. Sat down that night and ordered a brand x 150.
Posted : 28/12/2017 12:08 am
Was about 0 at Lee Quarry earlier and all our Reverbs were a lot slower. Definitely because of the temperatures.
The hairs on my new tyres even had icicles handing off them!
Posted : 28/12/2017 12:58 am
Have you tried slackening the seat clamp. Had a mate with a KS lev that didn’t appreciate having a tight seat post clamp - slowed it right down. I’m wondering if the contraction of the seat clamp bolt might have an impact on the operation?
Posted : 28/12/2017 1:04 am
It must have been well below freezing yesterday with the wind chill and the speed return and clamp were both tried and to no avail.I will try a bleed and air today failing that Lbs can sort it as it's less than 6months old
Posted : 28/12/2017 9:09 am
Bikes don’t feel wind chill...
But get a DEhy conversion kit, they’re brilliant.
Posted : 28/12/2017 9:13 am
Had this a few years ago on my old ht, turned out it was just low on air pressure.
Posted : 28/12/2017 10:53 am
Prognosis by Lbs... Bleed and while it's there rear shock service and a new set of wheel.. 😉 why not
Posted : 28/12/2017 12:07 pm
