2012 xt axle questi...
[Closed] 2012 xt axle question
Hi guys , just taken the axle out of the rear wheel ,not seen these before , think its 15mm diameter and it has 9mm adapters on the ends , one end has been stripped of the threads ! Can I get a replacement axle ? If so where from and what do I ask for ? Cheers guys
Thanks Paul
Posted : 05/12/2012 8:00 pm
Have a look at the hub, there should be a code on it FH-M or WH-M something. Stick that in google with EV for exploded view after it. This will bring up the spare parts diagram. Report back with the part number you need.
Posted : 05/12/2012 8:29 pm
Hi mister p, the model and name is
Hub axle unit y-3cz 98020
Hope you can help . Can I just fit a standard 9mm axle in ?
Posted : 05/12/2012 8:49 pm
