2011 specialized st...
[Closed] 2011 specialized stumpjumper dt swiss wheels-are they tubeless ready
as title,do i just need valves or tape as well? anyone help please
Posted : 07/03/2012 8:00 pm
Yes, You should have had the valves with your manual
Posted : 07/03/2012 8:02 pm
Do the supplied valves just push in and tighten with the lock nut? I have tried them but i have leakage at the valve when i try to inflate them.
Posted : 11/03/2012 9:13 pm
 bol
If you put some Stans in it should cure the leakage pretty quickly.
Posted : 11/03/2012 9:39 pm
Mine on a 2010 stumpy required more tightening than seemed reasonable.
Posted : 11/03/2012 9:57 pm
To be honest i tried it without sealant as i didnt have any and wanted to see if it worked!
Is stans the best to use?
Posted : 11/03/2012 10:22 pm
I had to use pliers on my valves to get them to seal.
Also the blue plastic rim tape was very wonky so took it off & replaced with electrical tape.
Posted : 11/03/2012 11:26 pm
