Hi all,
wanting to service my 09 revelation dual airs for the first time and i was hoping for some advice since ive never serviced forks before!
are there any online manuals or guides as i cant seem to find any!?
any help/hints/tips would be much appreciated!
ta
Ben
Try here
http://www.bikeradar.com/gear/article/workshop-rockshox-revelation-lower-leg-service-24649
should be right.
is it a good idea to change all the seals and wipers? mine look to be ok but im not 100% on what to do. is just an oil chnage and a wipe down enough?
the forks are still working fine - just thought i'd have a go at servicing...
You can get a service kit from tft that comes with all the o-rings & stuff but you shouldn't really need it if you are just doing a lower leg service & sticking some new oil in.
You will need decent circlip pliers though or you will knacker your circlips & have to replace them. And make sure that the pins on the circlip pliers are small enough to pass through the holes in the circlips.
