2009 Reba travel he...
[Closed] 2009 Reba travel help
hi guys, i know how to change travel etc on rockshox etc etc but can a 2009 aftermarket reba race dual air run at 120 travel if they came set at 100mm, are the stanchions the same length if you bought a 100mm or 120mm fork
cheers
Posted : 06/12/2011 3:56 pm
yes & yes just remove the spacer on the air piston rod
Posted : 06/12/2011 5:21 pm
Nothing in here to suggest you can't run a 2009 Reba Race at 120mm.
[url= http://www.sram.com/_media/pdf/rockshox/dealers/TM_MY09_E.pdf ]RockShox MY2009 Technical Manual[/url]
I've converted 2009 SL's from 120mm to 100mm, so expect you can go the other way on the Race version.
I believe they are exactly the same apart from the way the floodgate is adjusted; Race (external) vs SL (internal).
Posted : 06/12/2011 5:29 pm
ah cool cheers guys
Posted : 07/12/2011 9:39 am
