2008 Rockshox recon...
[Closed] 2008 Rockshox recon race - Can you extend it to 120mm?
I've been looking and can't find any info. Anyone know if it is possible?
Posted : 12/06/2013 9:55 pm
are yours the solo air? I have some from around that era and managed to get them up to 130mm best way is strip it down(make sure u already have the replacement fork oil) and see if it has any large half moon shaped spacers on the left hand rod that u can clip off(one with the air cartridge) if so then yes u can ๐Ÿ˜€
Posted : 12/06/2013 10:11 pm
Yep, pretty sure they are solo air. Cheers, I'll strip them down and have a look ๐Ÿ™‚
Posted : 12/06/2013 10:20 pm
real easy job can be done while in a work stand just make sure u put a catch tank of some kind under the left leg before u hit the rod from the lower bolt hole or ul end up in a messy pickle of fork oil
Posted : 12/06/2013 10:27 pm
