As per the title, which 20" (or 18") Schrader tubes work well on narrow rims (18 & 19mm) for ghetto tubeless?
I can confirm that no metal Schrader valves work (reinforcing patch in tube too large) long term, so it [u]must[/u] be a rubber valved tube.
Anyone?
what rims and tyre? I am getting away with just yellow tape currently
Schwalbe 20" tubes worked fine on my Alex rims, and have a metal (threaded) valve stem. If they're welded rims you've got, just yellow tape & sealant.
£2ish tesco 20" tubes have "rubbery/plastic" valves and worked for me on narrow 26" rims.
Im not sure what your problem is exactly?
In general? It's a long story..
Oh I see...
I used Schwlabe 20" Schraders, but the valve base/reinforcement patch was too wide for the 19mm inner rim width and wouldn't let the tyre bead seat 100% there.
Rims are 559x19 Weinmann Zac-19 and 559x18 Specialized/Alex HRD.
The ghetto tubeless worked, but then on more than one occasion overnight complete pressure loss occurred. A quick Google search and the best ghetto tubeless guide specifically mentions this problem with 19mm and under rims, and suggest using Presta valved tubes instead. In the comments section the author does however mention that rubber valved Schraders do work, but not which ones (if indeed there is a preference).
That's reassuring. Do you recall/know which rims/how narrow?
Well for me - some DT swiss rims that came named / un-modeled on a commencal bike. 19mm wide claimed. Happily went ghetto with tesco 20"tubes.
I'll give 'em a try and report back. Cheers.
gorilla tape and an old valve from a heavily repaired tube for me
