not going to be a prob using a middleburn uno with a 1x9 set up is it???
just chainline issues perhaps??
will use a ft mech to keep it on.
Aren't there any downhills where you live? that looks so limiting.
no drop device needed
you're either riding on the road or not riding it like you should be!
you don't have a bashring to keep it from offing off the outside or anything to keep the chain coming off the inside. ime that's double the trouble.
on my set-up it required an outer retainer (bash) and an inner n-stop device to eliminate chain offings on bumpy track. Trying to run extra tension helps a little bit.
Im with HTTP404 beeen running 1x9 with just an outer bashgaurd on a ramped chainring now for 2 months and chain comes off all the time . Definately go for something on either side if your going off road i was thinking of something like [url= http://www.dmrbikes.com/?Section=products&pageType=item&category=3&CategoryName=Chain%20Devices&itemid=CDCC2 ]this[/url] what do ya think?
maybe its just me who found the DMR chain device flexy and rubbish at keeping the chain on. If it is just me then does anyone want to buy it off me?
The new MRP top guide look good though, not on sale yet AFAIK.
In the two years of riding my SIR 9 1x9 I have NEVER lost the chain. It looks clean, and it's lighter.
1x9 for a few years here now. Middleburn/ Surly SS/ Short cage mech. Lost the chain 3 times, mostly on the black at Laggan at speed. It is a touch rougher than the average trail though.
Uno ring puts the chainlie a bit further out than you want. SS ring on the inside of the spider with a 113 BB axle is spot on.
hmm, looked at it again today, think i'm gonna use a different c/set, as the chain line is so off. might make it 2x9 now... thanks ๐
I use a Shimano UN72 113mm BB and I have ran 1x9 and SS and chainline is fine.
I know some folk have chain drop problems with their 1x9 set-ups, but as I said I haven't. I regularly ride steps, chunk, trail centres, 1-2' drops. Short cage rear mech and tight chain is all I have done.
I find I can get up (& down) almost everything I ride. The pic is with a 32t Uno, although at the mo I have a 30t fitted (clown size wheels) which has slackened the chain some, but still no drops.
