Where you've got it. Got a DMR speed guide if you want to try it above the chainring for extra security Oxo.
On the top I'd say.
very nice indeed paul....
Got those Nukeproof bars ton. 760 wide, **** me!
i have em on the ventana and the stiffee, they are very good.... 8)
Pfft 760mm. Gonna try some of the syncros 790mm ๐
๐
Ghetto tubeless was a doddle on those rims too. XC717's Advantage Rear/High Roller front. Nowhere near the nightmare I had with the stans strips on XM321's.
Thats lovely mate.
Would look good with some black (Hone) cranks.
Will the chain come off...I have no idea!!!
ghetto just seems to work great i had loads of faff with my dt rims with dt tubeless kit i tried ghetto on on other xm321 and it worked straight away no problems . Still hold air better than my proper set up lol
i allways thought the bottom chain guide should be just touching the chain plus 6-8mm or a tad more. to me yours is set way too tight, prob to compensate for too long chain, or have i been missing the point all these years? (quite possible) :o)
mick, yours hold air better cos they never get any weight sat on em.... ๐
I don't know, I figured the more chain I could wrap round the cog, the less chance it could fall off. I also think there's more chance it'll suck and hit the stay, as it's nearly there already, only time will tell I suppose
paul if it works it........works... 8)
paul if it works it........works... [8)]
true. but i would imagine the amount of tension being created on the guide is going to wear the roller out pretty quick.
i personally weould put it on the top, to keep the chain on the front ring. The rear mech can keep it on the sprocket at the back ๐
That bike looks great fun
lol tony ๐
Roller where it is. If you want to put something on the top, it should be a cage of some sort. Or an [url= http://www.billys.co.uk/english/group.php?prod=chng-js ]N-Gear Jump Stop[/url], cheap and effective.
Is a chain retainer on the front necessary on a 1x9? or can you get away without one?
depends how you ride vortexracing, there was a good thread on mtbr about 1x9's
I'd say it's essential to have a top guide on a 1x8/9 setup, once you've lost the chain pedalling over some roots/bumps, and had a knee-stem incident because of it, you will agree!
Would go for a cage style guide at the top, can be a bit fiddly to set up at first but with a little time and adding/removing of small washers/spacers can get it running silently with no way of letting the chain jump off.
There've been a few threads on 1x9 on here recently. Consensus seems to be that chain flings around all over the place without a tensioner and that a Jump Stop and bashring is the best way to keep it becalmed.
It's a pity cuz I'd love the simplicity of 1x9 without those bits and pieces cluttering up the bike.
only reason i was asking was that I was considering it on my new Alpine.
I was looking at the Gamut P20. Light and simple.
"seems to be that chain flings around all over the place without a tensioner and that a Jump Stop and bashring is the best way to keep it becalmed.
It's a pity cuz I'd love the simplicity of 1x9 without those bits and pieces cluttering up the bike."
Using an unramped (one not designed to do any shifting) has longer teeth (deeper than the chain) stops the chain falling off 99% off the time (lifting over gates/in crashes are where it tends to come off), and lets you get away with just a chainring though
I've just done exactly as suggested by James; unramped FSA DH chainring, an N-Gear Jump Stop, and a BBG Bashguard. Has worked a treat so far.
D'oh, forgot to mention the bashguard, although I was thinking it. Decent unramped chainring (SJS Cycles do some really nice own brand ones for not much cash), bashguard and a jumpstop and you'll have no problems. Also looks a lot nicer/cleaner than a cage!
god yeh, stick it on the top. I use an old mech wedged open with the plastic bit that comes with it to help you set it up. It's never come off once.
I used to use an n-gear jump stop (aesthetically looks great and weighs nothing) combined with a bash and unramped chainring. That worked well. I'd be interested to retry with a much shortened chain and short cage rear mech as per bonesetter because looks wise it would look cleaner for sure. Crunchy nuts for breakfast and not for the sake of losing a chain whilst MTBing. ๐
Bonesetter, that is one gorgeous chainring (if a chainring can be considered gorgeous). Is it a Boone?
... you could go 1x1 ... even better ๐
AdamM - MemberBonesetter, that is one gorgeous chainring (if a chainring can be considered gorgeous). Is it a Boone?
Adam - Yes It's a Boone, and yes isn't it just gorgeous.
Even makes the good looking 'burn's look rather normal
I have/do/am!
Love it. That's why I can't bring myself to put bits n pieces on my bike. But I like the idea of the increased versatility of having a few gears to get me around faster and help me out on big hils whilst still retaining some of that simplicity. Could be a good compromise.
I might give it a go and see how it goes.
