1x12 gear ratio ste...
[Closed] 1x12 gear ratio steps - SRAM 11-50 and Shimano 10-51
Anyone have any experience to share on if the ratios and spacing on these make much difference or you find either preferable at all? (geek alert)
12 11 10 9 8 7 6 5 4 3 2 1st
11-13-15-17-19-22-25-28-32-36-42-50 - SRAM
10-12-14-16-18-21-24-28-33-39-45-51 - Shimano
5th is the same on both. The lower gears on the Shimano are larger/easier, the higher ones smaller/harder, and the spacing at the lower-end is notably different.
The 5-6 gap is 1T larger on the Shimano, then the subsequent gaps are the same (teeth-wise) on both so each gear on the Shimano is 1T smaller/harder. That's by 4% for 6th, rising to 10% for 12th.
SRAM has a big 8T (19%) 1-2 gap followed by smaller 6/4/4 gaps to get to 5th. Shimano has more even gaps of 6/6/6/5 but they are larger due to the absence of that big first gap - instead you get 18% gaps for both 3-4 and 4-5. The actual ratios below 5th are all easier on the Shimano though.
Not sure what to think as I haven't ridden either yet and might not be able to try both. Seems the Shimano is better for hard climbs in 1st-3rd but you might not get as much use out of 11th and 12th depending on your usage/chainring/wheel size. If you rarely use 1st/2nd maybe SRAM is more suitable, and just occasionally be in a slightly-off gear (or stuck in 1st below that big gap) on those hard climbs.
I found this in a Shimano XT review from Pinkbike:
As explained to me by a secret development rider, Shimano's 18-percent jump from the 33 to a 39 was chosen to keep the first nine steps as close as possible, while segregating the three largest cogs (clustered in even, six-tooth jumps), specifically as climbing gears. SRAM's gearing, on the other hand, was intended for riders who prefer a more sequential gearing progression across the cassette. True or not, Eagle and XT cassettes have distinctly different personalities on trail.
Posted : 07/07/2020 10:20 pm
Honestly it never even crosses my mind when I'm riding.
Doing lots of road miles on the gravel bike, with 1x11, yes it can mean there's a big jump in cadence from one gear to the next.
On the MTB? not an issue. Get the 10-52 SRAM or the 10-51 Shimano.
Posted : 07/07/2020 11:59 pm
I've got the 11-50 cassette and I haven't yet felt that the gaps are too big. I also ride a road bike with quite a narrow ratio block (as we called them when I was racing many years ago) so I'm fairly sensitive to the feeling of "not quite the right gear".
Posted : 08/07/2020 9:37 am
As above, don't really notice. I moved from Eagle to Shimano, and in theory I should prefer 45-51 to 42-50, but I have never consciously registered the difference when climbing.
Posted : 08/07/2020 9:46 am
On smaller cassettes I've always preferred smaller jumps between the larger cogs - this is where you are working hardest/feeling worst - so more choice of gears is better.
Posted : 08/07/2020 9:48 am
Sram 12spd is 10-50, or 10-52
Or did you mean Sunrace?
10-12-14-16-18-21-24-28-32-36-42-50 – SRAM 10-50
10-12-14-16-18-21-24-28-32-36-42-52 – SRAM 10-52
10-12-14-16-18-21-24-28-33-39-45-51 – Shimano 10-51
Posted : 08/07/2020 10:08 am
Except NX.
Posted : 08/07/2020 10:10 am
ah yes, sorry. I assumed the OP was comparing like with like, so all starting at 10t
Posted : 08/07/2020 10:16 am
reggiegasket
Member
Cheaper SRAM (the ones that fit a standard freehub) are 11-50
This is based on the numbers that @reggiegasket posted above. Shimano looks a much smoother progression. (Christ, how sad/bored/geeky am I?)
Posted : 08/07/2020 10:28 am
Had 10-50 SRAM on the old bike 10-51 Shimano on the new bike.  Can't say I really notice a massive difference apart from the shifting down at the low end. Shifting from 3 -> 2 -> 1 gears is much smoother on the shimano. Now that could be the different shifting ramps setup or it could be the more even split between ratio's.  I was always careful going into the 50 on the SRAM as it was never a happy sounding shift, coming back down off of it you could almost hear the relief in the chian to have made it intact.! 🙂
No such issues with the Shimano, every shift is smooth and pretty much silent. LIke I said though, not really comparing like to like as the Shimano shifting ramps have always been better IMHO.
Posted : 08/07/2020 12:52 pm
Swap between SRAM 10-50 and Shimano 10-51 and didn't even realise there was much difference until i read this post!
Posted : 08/07/2020 2:48 pm
Nice chart @honourablegeorge, would you mind adding the SRAM 11-50 to it please? Being pretty common on "low-end" bikes.
Posted : 08/07/2020 3:26 pm
I have SRAM and last year I noticed the difference a lot more. Over winter I worked on my cadence range and now can sit comfortably between 70-100 RPM so I can easily modify my cadence to suit the gearing at that point. I change gears less looking for the ideal gear as I can adjust my leg speed to suit what I need to do.
Posted : 08/07/2020 3:39 pm
These are the percentage jumps, from small to large sprocket.
[url= https://live.staticflickr.com/65535/50089871053_9cc965da8d.jp g" target="_blank">https://live.staticflickr.com/65535/50089871053_9cc965da8d.jp g"/> [/img][/url]
Posted : 08/07/2020 4:15 pm
as highlander says, the shifting on the Shimano at the low end (gears 3-2-1) is smoother baecause the percentage change is smaller than the Srams, as seen with the dashed line dropping off on the right side of the chart.
Posted : 08/07/2020 4:23 pm
New chart below, I think Reggie's one better illustrates how the shimano varies less though
Posted : 08/07/2020 4:59 pm
With Sram 11-50 added. Very similar to Sram 10-50
[url= https://live.staticflickr.com/65535/50090845902_bcc183bc5a.jp g" target="_blank">https://live.staticflickr.com/65535/50090845902_bcc183bc5a.jp g"/> [/img][/url]
Posted : 08/07/2020 5:12 pm
@reggie Busy day at work for you too, eh?
Posted : 08/07/2020 5:25 pm
Nice chart @honourablegeorge, would you mind adding the SRAM 11-50 to it please? Being pretty common on “low-end” bikes.
Posted 1 hour ago
Have a look at the first post
Posted : 08/07/2020 5:27 pm
Ramsey Neil
Have a look at who made the first post 🙂
Posted : 08/07/2020 6:11 pm
