I'm chasing options for 160mm cranksets that will work with chains that are compitable with Shimano 12sp chains? Is there anything available other than the new RaceFace turbines? As far as I can tell, everything else seems to be all SRAM/KMC chain compatible, not Shimano 12sp.
๐
Cheers. I'll take a look at those options.
Hope and rotor do at the premium end, just get a chainring that's 12s Shimano compatible. Lots of companies used SRAMs 3 bolt design for chainring attachment. Anything in the correct length that uses that could be used as there are 3 bolt SRAM for chainrings available that are Shimano 12s compatible.
Unite components do 155-175 length cranks. They've switched back to anodizing from cerakote as well now which was the main problem people were having with Unite.
raceface era's, hope's....there's usually a 3rd party chainring that works, I'm running a 165mm x01 with a DMR chainring on an XT drivetrain.
