140mm pike airshaft...
[Closed] 140mm pike airshaft?
anyone know where i can get a 140mm airshaft for a 27.5 pike in the UK?
Also how easy is it to chnage
Oli
Posted : 05/03/2015 9:08 pm
They're relatively easy to shorten if you're already on the long side. Got mine done a couple of weeks ago by Bad Ass Bikes...
Posted : 05/03/2015 10:18 pm
Piece of cake to change them. Guide on the Pike Manual on Sram website. I got my 140 air spring from Germany, cost about £25. I'll see if I can find the site again.
Posted : 05/03/2015 10:44 pm
I bought a 130mm just after Christmas and couldn't find them anywhere but the states, so that's where I got it from.
Posted : 05/03/2015 10:50 pm
I cut 10mm off my 15 shaft with a hacksaw and filed it carefully to the same shape. There is a thread about shortening them somewhere on mtbr. Machine shops or Loco will do it properly for you, but the cost might be around the same as a new air spring.
Posted : 05/03/2015 10:58 pm
You tryrd tftuned?
Posted : 05/03/2015 11:04 pm
Worth bearing in mind a hacksaw to the air shaft will void the warranty, if it still has one.
Posted : 05/03/2015 11:54 pm
LBS order part through Fisher and give it to you to fit?
Posted : 06/03/2015 12:00 am
 cnud
Got one off Amazon recently for my Solo
Posted : 06/03/2015 1:41 am
 LoCo
Yes we hold them in stock, easy change if you can do a lower service and have some circlip pliers you'll be fine, will need some 0w30 oil to refill the lower with though
Posted : 06/03/2015 12:42 pm
 pdV6
My LBS got one from Fishers.
Couldn't source a 130mm one though.
Posted : 06/03/2015 1:18 pm
